Why is it that only one of my speakers work sometimes?
Old Oct 6, 2012 | 07:09 PM
EvoTillIDie's Avatar
So I recently changed my stock non-bose speakers in the front for some Pioneer TS-A1674R's....... They sound great & I can't wait to change the rears....The only problem I have is that it has its tendencies to go out when I hit a pothole, close the door or any "hard" vibrations encounter it.........I double checked the wires & all, they're hooked up correctly......Should I send the speaker to Pioneer or try to see if Best Buy will replace it?
Old Oct 6, 2012 | 11:38 PM
AscendantMax's Avatar
the speaker leads going to the VC might be bad. are you SURE everything is connected securely?
Old Oct 7, 2012 | 07:44 AM
What's the VC? How do I check if it is the problem? & yeah I removed the door twice to check the connections and they're always right
Old Oct 7, 2012 | 05:20 PM
stock everything else?
vc = voice coil. if you look under the speaker, you'll see two wires leading towards the middle of the cone. the wires go to the voice coil deep inside the magnet. these wires can go bad so you may have intermittent connection whenever you hit a bump etc. if you have a multimeter handy, just connect the probes to the + and - on the speaker and see what kind of resistance you're getting. if the speaker leads are bad, you wont get a reading.
Old Oct 7, 2012 | 05:39 PM
Yea completely stock.....Hmm I might have to check this out tomorrow hopefully....If this is the case what can I do? Send it back to Best Buy?
Old Oct 7, 2012 | 07:14 PM
yeah I'd send it back for being a defective product.
Old Oct 7, 2012 | 07:44 PM
Might just jump straight to that lol thanks for the help
MikesChevelle
Nov 23, 2024 11:17 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
jskirwin
Jun 8, 2016 08:49 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
