Is this all i need to install my new stereo?
Old Oct 24, 2012 | 02:12 PM
skratch's Avatar
Just to confirm is this all i need to install my new stereo in my 96 maxima with bose sound system? Buying this JVC stereo tommorrow
Metra 99-7417 Installation Multi-Kit
Metra 40-NI10 Nissan Antnna Adapter
Metra 70-7551 Amplifier Integration Harness
Old Nov 3, 2012 | 10:51 PM
skratch's Avatar
bump
Old Nov 3, 2012 | 11:48 PM
rebelhell's Avatar
I love how when you have an audio question they tell you to post it in the audio forum. And then nobody ever responds in the audio forum.
I'm a 5.5 Gen Owner but I'll try to answer your question. It looks like you have the right adapters listed. I would also recommend a soldering iron, solder, flux, and shrink tubing.
Your problem is going to be (and don't quote me but it's an issue with 5th gen Bose) that stereo you picked out only has 2.5 volt Pre-Outs. The factory amps require 4 volt pre-outs. You are going to have trouble getting any volume out of your new system. I would pick another radio and pay attention to the number of pre-outs and their voltage. Again you need two sets (front and rear) and they must be at least 4 volts.
Old Nov 4, 2012 | 01:37 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Don't need the last one. A 70-7550 will work just fine.
Old Nov 4, 2012 | 01:05 AM
rebelhell's Avatar
With the 70-7550 you have to bypass the factory amps and you'll get poor quality audio in my opinion. Most head units aren't designed to work with the Bose 1ohm speakers and you can actually damage the head unit's amplifier that way. Read this. http://carstereohelp.net/gotquestionsQ10.htm
Old Nov 4, 2012 | 09:02 AM
Pearl96Max's Avatar
Negative. Connect it as a standard harness. No bypassing or running to each driver is needed.
Old Nov 4, 2012 | 09:51 AM
AscendantMax's Avatar
^ what he said
Old Nov 4, 2012 | 05:05 PM
skratch's Avatar
positive?
Most of the stereos are 2volts,
and i dont need a Scosche SLC4?
Old Nov 4, 2012 | 07:15 PM
Pearl96Max's Avatar
Originally Posted by skratch
positive?
Yes I am positive and no, you don't need Any sort of adapters.
Old Nov 5, 2012 | 06:00 PM
skratch's Avatar
i got another question u think i should just buy another amp aswell to make the sound better?
Old Nov 5, 2012 | 06:24 PM
Pearl96Max's Avatar
That is up to you, but with OE speakers it will not make a drastic change. Especially not one to offset the cost of the amp, cabling, installation, etc.
Old Nov 7, 2012 | 03:48 PM
skratch's Avatar
thanks appreciate ur help, if i was to get a amp does it have to be a specific one or i can get anyone? 3 months later i do want to replace the rear speakers since they do pop alittle when the bass is turned up
and does anybody know of any decks has volts? i get bestbuy discounts and i dont see any on there site, saw some on amazon but it doesnt say whether it works in my car or not,is there a list of some sort
Edit:
i think im going to get this stereo http://www.crutchfield.com/p_113KDCX...5.html?tp=5684
Old Nov 7, 2012 | 08:25 PM
Pearl96Max's Avatar
Any half way decent amp is fine.
ALL decks have 'volts' it is just where and how they are. I believe you are still struggling with the thought that you need 'high voltage' preouts - you do not.
Good choice, I sell a ton of them.
Old Nov 23, 2012 | 08:37 AM
rebelhell's Avatar
Edit
Old Nov 29, 2012 | 05:22 PM
skratch's Avatar
i finally got my stereo installed and it sounds nice way better than the factory one, now my O/D off light keeps coming on how do i switch that back for it wont come on no more?
Edit nvm i just had to press the button to turn it back on
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
EdRomo86
Sep 12, 2015 07:49 PM
Violator
Sep 9, 2015 10:14 AM
Johnny9595
Sep 3, 2015 05:18 AM
