Much Rattle, Even after Dynamat - Please Help?
Old Jan 18, 2013 | 01:30 PM
ChicagosFinest's Avatar
This is from another thread... seems as if I posted in in wrong spot
I have a 2003 MAX SE
I got 2 15's and recently installed them with a decent amp and wiring kit.
I recently notice that nissan even put some factor deadening material inside the trunk (which ain't sht but every bit helps!)
Anyhow, they ran out of dynamat and still I have some spots to lay out some dynomat.
With that said, I have some powerful *** subs - Dynamats in but still get a nasty nasty rattle at higher sound levels.
I was wondering if anybody had any knowledge of where this car rattles the most and how to fix?
Anything else I can add to fix rattle issues??
Thanks.
MIND you - my car is already dynamatted.
Old Jan 18, 2013 | 01:37 PM
now mind you much rattle is also gone as wel, but the trunk flexes (of course) and its too much, are there any looses ends in the stock sub unit? its not hooked up, but it rattle as well. Input please, any weak spots etc
Old Jan 19, 2013 | 02:43 AM
Hectic's Avatar
Why do people think Dynamat eliminates rattles? Rattles aren't caused by air bouncing off bare metal, they're caused by plastic and or metal vibrating against one another.
With that in mind, find where it's coming from and insulate the parts of the car that are banging against each other.
Old Jan 19, 2013 | 03:47 PM
1996blackmax's Avatar
Check the rear panel behind the seats. This area can get annoying rattles.
Old Mar 4, 2013 | 05:16 PM
BrooklynCyclone's Avatar
Is the rear deck dynomatted as well....also the trunk lid could be foamed but must be done carefully so not to risk rippling the top of trunk from to much expansion....dynomatt the back of the plate ,and make sure your taillights are tight and anything else that's screwed down and around back there ,good luck..
Old Mar 5, 2013 | 04:44 AM
nismos14's Avatar
§è~® f®ÈÄk
Turn the bass down
user 11122324
42
Jul 18, 2022 03:35 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
