?? 7th gen alternator??
Old Mar 21, 2013 | 06:42 AM
StephenPerry213's Avatar
Hey I'm new here but I wanted to upgrade my system even more and was womdering if there is a upgrade to our alternator for the 7th gen. I currently am running two amp but want to end up running 4 amps
Old Mar 21, 2013 | 07:32 AM
FastnFuriousMax's Avatar
it isn't the number of amps it is the current you will be drawing.
how much will all 4 amps draw at max?
you likely will be fine with a big 3 upgrade and throwing a 2nd batt in the trunk.
Don't buy optimas they are pieces of **** and so is their company.
edit: Why 4 amps and what components are you planning on using out of curiosity?
Old Mar 21, 2013 | 08:22 AM
I have jl comps in the front doors tweeters in dash where the old ones where jl 6.5in rear deck and 6.9 in the rear doors. Running a 600/4 jl hd amp with a jl 10''w7 with a 750/1 hd amp. But I want to go with a 12 w7 and 2 8'' w7 with 2 more 500/1 hd amps
Old Mar 21, 2013 | 09:08 AM
you should be fine on the stock alt if you do the upgrades.
Old Mar 21, 2013 | 10:10 AM
Cool thank you. Still think in should do the second battery
Old Mar 21, 2013 | 10:27 AM
I would do the Big 3 at a minimum. If your lights still dim and you have voltage drop install a second batt in the trunk. No Optimas!!! No Caps!
Old Mar 21, 2013 | 10:52 AM
Ok cool thank you
Old Mar 21, 2013 | 11:46 AM
Also why do you say no caps
Old Mar 21, 2013 | 12:36 PM
they are a band aid and rather useless. A second battery is MUCH more useful
Old Mar 26, 2013 | 03:13 PM
MaximaDrvr's Avatar
A capacitor will empty in under a second. Then your alternator is trying to recharge the cap, plus run everything else.
They are useful in bass burp competitions, but terrible for everything else.
DJLAX152
May 4, 2021 11:46 AM
2012Maximus
Sep 10, 2015 12:50 AM
Wareagle92
Sep 3, 2015 07:18 PM
