Amp Settings
Old Sep 2, 2013 | 09:42 AM
Ade Hayes's Avatar
Amp Settings
I have had a sen21100 amp for a few years. I have lost all of the paperwork for the amp and don't remember the correct settings. I have it installed but I am not happy with the overall sound quality. I am hoping someone here can tell me the correct way to set these. I have 2 10" woofers in a 4ohm config I believe the amp is 1100 watts and I have it bridged. Any help would be appreciated
I am pretty sure I need a bigger capacitor
Old Sep 2, 2013 | 11:23 AM
1996blackmax's Avatar
What size power wire are you using? I've never used a capacitor, just made sure all my connections were correct, as well as using proper sized quality wire.
I see you have a ported enclosure, using a subsonic filter will help.
Old Sep 2, 2013 | 03:45 PM
Ade Hayes's Avatar
Should I turn it all the way down? I am using 4gauge power and ground wires
Old Sep 2, 2013 | 08:45 PM
4ga is good if its a quality cable. I would turn the bass boost down if it's on, then readjust your gains from there.
JL has a good tutorial on setting your gains.
http://mediacdn.jlaudio.com/media/mf...pdf?1351723085
http://www.jlaudio.com/header/Suppor...Setting/287546
Old Sep 3, 2013 | 08:16 AM
Ade Hayes's Avatar
Thank you. That is what I needed
Old Sep 3, 2013 | 05:50 PM
Your welcome, glad that helped.
aw11power
Oct 10, 2021 04:57 AM
chisam14
Nov 6, 2018 08:56 PM
knight_yyz
Nov 1, 2015 01:34 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
