FS:Kenwood MONO Amp:600RMS:1200Peak:
Old Jan 23, 2002 | 08:58 AM
eric93SE's Avatar
FS:Kenwood MONO Sub Amp:600RMS:1200Peak:
http://kenwood.carclub.ru/power_apli...ac-ps400m.html
First of all this amp is in mint condition, I baby all my electronics. I am selling b/c I have upgraded. This amp is incredible not only does it have insaine power, its is also the cleanest I have heard yet!! This is greatly due to its insainly high damping factor (@ 9900), most amps are rated at between 200 to 600 for there damping factor. This Kenwood amp uses a circuit called Sigma-Servo and has an addition set of leads that run to the speaker(s) which allow the amplifier to have the control that is needed to have clean and accurate bass out of your subs (NO MUDDY BASS OUT OF THIS AMP!!) clean and deep bass. When I competed in IASCA (Internationl Autosound Competition of America), I placed first every time in my class. With ONLY One Tweleve inch sub I hit 141 DB's. I competed in NY,NJ,RI,CN and placed first in each competion. This amp is MONO which means it has one set of outputs, but is designed to run at TWO ohms. If you want you can run it at four ohms, that is not a problem. What is great about this amp is that you simply run two subs (four ohm) in parallel, then you will have your two ohm load, so the amp will put our full power (600 rms and 1200 peak). Or of course you can run one sub that is dual voice coil and put full power into that one sub!!.
Other great features:
-Selectable infrasonic filter (protects your subs from blowing)
-Variable low pass
-Dual internal cooooooling fans!!
-Oversized (Huge) power connectors
[edit I forgot to include something]
-Variable Band Regect filter (Allows the removal of a narrow band of bass....this is used when Bad resonance is occuring, like trunk rattle.)
The amp went for between $650-$700
I am selling this beauty for $250 Including Shipping
Old Jan 25, 2002 | 07:35 AM
eric93SE's Avatar
bump
pdc001
Aug 25, 2002 11:16 AM
GoNe
Feb 7, 2002 04:23 AM
ngthing
Mar 5, 2001 06:10 PM
