running amp power cable
Old Feb 2, 2002 | 11:00 AM
WaydeMax's Avatar
I'm having trouble finding exactly the right spot to run the power cable for my amp in my 97 max gxe. I can't seem to find a good place in the firewall. Should it be under the steering wheel to the left of the pedals or on the passenger side somewhere ? If anyone has done this before or anyone that knows specifically where to put it, it would help.
Old Feb 2, 2002 | 07:30 PM
mb1's Avatar
mb1
search...
Old Feb 2, 2002 | 10:21 PM
95emeraldgxe's Avatar
on the drivers side.......
Old Feb 4, 2002 | 09:44 AM
studman's Avatar
Make it easy on yourself. Remove the driver's front fenderwell covering. Then you can see the firewall from the wheel. Insert a coathanger (or some other strong, small object that won't puncture a wire) through the firewall. Get a flashlight, and look up under the driver's panel. It should be to the FAR LEFT side, like it's directly connected to the SIDE wall instead of the front wall. It's about 1-1.5 feet above the floorboard. That should make it easier to find. Then use a flat blade screwdriver or other object to make a hole big enough to get the wire through.
Old Feb 5, 2002 | 05:55 AM
WaydeMax's Avatar
thanx u guys, especially studman, for your help, hopefully I will be able to do this.
Old Feb 9, 2002 | 05:01 PM
pjalst
me too
If you find it let me know, I'm doing my install a week from now.
Old Feb 9, 2002 | 09:18 PM
FJC's Avatar
FJC
Guys, run it on wither side. Preferrably on the fusebox side. You want your Patchcords running on the OPPOSITE side ALWAYS!!! Keep the patchcords away from power sources, even if you run good cords...
E-mail me and I'll hook you up.
vingodine
45
May 21, 2016 12:46 PM
melteye
May 16, 2016 12:02 AM
vybz05
Dec 10, 2015 07:38 PM
schmellyfart
Sep 25, 2015 04:47 PM
homeyclaus
Sep 3, 2015 06:15 PM
