Subwoofers with a bose system.
Old Feb 16, 2018 | 09:39 PM
Nissanfinatic's Avatar
I would like to install two ten inch subs in my 2014 7th gen. The problem is I have the bose system. I would like to know if anyone has had success in installing subwoofers with a bose system? If you have what components did you use?
Old Dec 26, 2024 | 02:12 PM
Shaun3181's Avatar
[QUOTE=Nissanfinatic;9168866]I would like to install two ten inch subs in my 2014 7th gen. The problem is I have the bose system. I would like to know if anyone has had success in installing subwoofers with a bose system? If you have what components did you use?
I used a JL audio LOC 22. It’s an active LOC. I had some trouble with the cheap passive LOc’s for 20-25 dollars.one of them was Rockford Fosgste even. I have an alpine A60m and 2 pioneer 4 ohm single VC 350 RMS speakers ran in parallel to two ohms. Sounds great. My daughter told me it was too much. I used JL Audio power wire 4 gauge. Do not use cheap power and ground wires. They will not be true to the size. I had electrical problems because of cheap wires. Good luck
gramenis
Jun 19, 2002 08:46 PM
DaveGrun
Jun 15, 2002 04:51 AM
Richy92SE
Feb 6, 2001 01:45 PM
