Were to connect my a REM wire on my none bose oem system?
Old Feb 8, 2002 | 09:21 PM
emax02's Avatar
I know on aftermarket decks the light blue wire is usually the REM wire but does anyone know what I should do on my oem head unit? I know I could probably tap into my clock wire or something but there's probably a easier way, right?
Thanks for any help
Old Feb 8, 2002 | 11:20 PM
mb1's Avatar
mb1
power ant wire, if you have one.
Old Feb 9, 2002 | 12:04 AM
emax02's Avatar
Theres no antena in 5th gens .
Old Feb 9, 2002 | 08:02 AM
Yellowbrother's Avatar
even tho 5th gen has no external antenna...but u guys do have "antenna" thas the only way ya'll could get radio station...so u actually do have a wire for "antenna turn on"...i know for sure that on a 96-97 honda accord does not have an external antenna but there was a "antenna turn on" wire...if u have stock deck then u can look for the "antenna turn on" wire and tap into that....or u can run ur remote wire to ur fusebox and put in a fuse...
Old Feb 9, 2002 | 09:15 AM
mb1's Avatar
mb1
Is there any kind of factory amp for any of the speakers? I recall my 3rd gen had a rear amp on a non bose system, and I used the remote from there. Or you can just connect it to the (car on?) wire.
Old Feb 10, 2002 | 10:03 PM
StaindMaxima's Avatar
You can just use the accessory wire behind the radio. The same one that turns the radio on. Even if your radio does have a power ant. wire, I wouldn't use it because usually they are wired so that when the tuner is shut off, like when you switch to cd or tape or whatever, the power ant. wire shuts off, meaning that unless you are listen to a radio station, that wire will not be powered. Obviously if the tuner is off the antenna doesn't need to be up....thus making it a bad wire to use for turning on an amp........to make a long story short....use the acc. wire.
ryan
Old Feb 10, 2002 | 10:19 PM
nismo1989's Avatar
Just wire it to the fuse that controls the radio...
When your stereo is on, be it the radio or whatever, the amp will turn on as well. Run the wire to the fuse box and plug it in where the fuse is.
Old Feb 11, 2002 | 09:50 PM
emax02's Avatar
Thanks for the help guys, I appreciate it! I will try taping into the fuse tomarrow
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
A32goldylocks
Sep 2, 2015 06:39 AM
umnitza
Sep 1, 2015 01:03 PM
doobadoo
Aug 15, 2015 06:43 PM
