wiring question...
Old Feb 13, 2002 | 04:17 PM
MaxedOut2g's Avatar
wiring question...
i want to get 4 10" blacklights for the interior of my car, place em under the seats and stuff...the wiring, i want to run under the seats or on the side areas concealed...now, the question is, can i just take all 4 power wires, crimp them together and run it to a switch and ground them to something else? i already have the switch and i want to run it to a fuse, but am i thinking about this properly or much more involved?
atw
Old Feb 13, 2002 | 09:39 PM
MaxedOut2g's Avatar
nobody knows anythng about wiring stuff? come on guysssss
atw
Old Feb 13, 2002 | 11:36 PM
Schmoo
Re: wiring question...
atw
I think you've got the right idea, though you aren't entirely clear. You do need to check the current draw for all the lights added together and make sure your wiring and switch are up to snuff (and to choose the right size fuse), though I think flourescents don't usually draw toooo much power. In any case, it's power -> fuse -> switch -> split -> lights -> combine -> ground. Make sure the power source you tap into can supply adequate current (if it's not the battery). You might want to incorporate a relay to only enable the circuit when the key is turned. Of course, if you find a good switched power tap in the first place, then you don't need a relay; but without some knowledge or a wiring diagram, it's hard to know what's good to tap into.
Old Feb 14, 2002 | 03:59 PM
MaxedOut2g's Avatar
Re: Re: wiring question...
hey thanks man, appreciate it
atw
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
