My car sounds terrible... why?
Old Feb 14, 2002 | 01:06 AM
Evil Yak's Avatar
I dont get it... I spent all this time installing
6.5's in my doors and tweeters in the A pillars.
I adjusted everything like 10 times now, messing
with the crossover points, etc. Can't figure it
out.. my system sounds like donkey farts.
I already tried messing around with phase, etc
I dont want to use a crossover cuz i'm into that whole KISS philosophy
Here's the setup:
Eclipse Component Series 6.5"
mids in doors, sealed up decently with caulk and dynamat
tweeters in A pillars, custom grille, flush mounted
tweeter attenuation set all the way down (I dont like harsh tweeters)
Eclipse Point Source 6x9's
bolted directly where old bose 6x9's used to be
Kenwood Excelon KRCX657 cassette deck
built in HP crossovers front set to 100hz
rear set to 80hz
Kenwood KDCD300 in dash cd player
Rockford Fosgate 800a4 running the mids
and highs... crossover currently set
to full range and bass adjustment all the way down
now one thing i cant figure is why i have terrible imaging
and staging bad midrange, unclear sound
my system does play loud with no distortion, but it just
doesnt sound good... i heard stock systems destroy my car
when i compare it to turbo95max's setup with
MBQuart something or others in the doors with tweeters in the doors
cheapie Clarion deck, rockford fosgate 600x4, his knocks mine
into the ground
I took out my subs for now, just concentrating on pure SQ...
Old Feb 14, 2002 | 04:37 AM
Micah95GLE's Avatar
You probably need to aim the the front speakers better, for a good left/right balance. Most tweeters are very directional.
Old Feb 14, 2002 | 07:52 AM
jmax
So far I agree with Micah. It could definitely be the tweeter angle, or a combination of the tweet angle and the mid angle. Of course there is also the fact that the tweet and mid are over two feet away from each other. Max'n'out had his tweets and mids a large distance from each other and I believe he used a 24 dB/octave crossover to accomadate. Have you tried adjusting the phase of each of the front drivers individually? Also, describe what you mean by - "bad midrange, unclear sound".
Old Feb 14, 2002 | 11:18 AM
Evil Yak's Avatar
well... the tweeters are pretty well aimed... not perfect
but they point in the general direction of center of the car
im getting tired of my car sounding like crap... is it the
components i'm using? i know those fosgate amps are garbage anyway
jmax-
to answer your question... the sound is odd... there is very
little left/right separation and the sound seems overly bassy
no matter what I do to it... the highs are loud and sharp,
and seem clear... but they dont seem to have the detail
of the music
my MR2 has a cheapie alpine deck running 4" infinity kappa components
and I think that car sounds nicer than the maxima
sucks
Old Feb 14, 2002 | 04:19 PM
Micah95GLE's Avatar
That's difficult to diagnose over the internet. That's kind of a hands-on problem.
Old Feb 14, 2002 | 05:56 PM
black019's Avatar
must be the installer
Old Feb 14, 2002 | 07:34 PM
Evil Yak's Avatar
true true hard to diagnose over the net
all the morons at my shop don't seem to have
an ***'s clue why the system sounds like it does
Old Feb 14, 2002 | 07:45 PM
max'n out's Avatar
Kinda hard to fix it on the internet, do you have a clue what your doing when you acually make adjustments? NO offence intended by that. But for imaging you need to first match the gains. Then if thats not enough you have to play with each drivers phasing. If that does not work you need and can't get away from new locations for the speakers ( kicks for example). You also should look heavy into an x over. With drivers large distances from each other i suggest using a lower slope. Ie my mids and tweets run active on a 12db slope, and the subs on a 24db slope.
Old Feb 14, 2002 | 08:06 PM
jmax
Lack of stereo seperation is normally a phase problem. Maybe a single tweet or mid out of phase, or a pair, or some other combination. Also, you could have crossed the speaker wires and might have the left tweet on the right side or vise-versa. Or the same thing but the mids instead of tweets. I once did this with my mids but it only took a few minutes to figure out.
Old Feb 14, 2002 | 09:16 PM
Evil Yak's Avatar
well... i'm very positive about the phase of the speakers
they seem pretty good... in general I'm quite good at tuning
systems, etc... i've installed quite a few high end systems
in cars, which is why this bugs me so much
you know, I think the tweeter positioining is probably
the biggest issue so when i get my car back, I think im gonna
do a complete teardown of my system and redo it
besides... my car needs a lot of work done soon
Old Feb 14, 2002 | 10:21 PM
puremax's Avatar
Re: My car sounds terrible... why?
Here's the setup:
rear set to 80hz
into the ground
Cuzz its a POS and you love Matthel too much!
Old Feb 14, 2002 | 11:10 PM
Evil Yak's Avatar
you should be one to talk... you and eddie seem
inseparable...
dumb half moon gay boys
Old Feb 14, 2002 | 11:12 PM
Brandon90gxe's Avatar
inseparable...
Old Feb 15, 2002 | 02:43 AM
black019's Avatar
inseparable...
you have your mouth permanently secured to matthels nuts
Old Feb 15, 2002 | 11:38 AM
Evil Yak's Avatar
oh, i didn't see you walk in
did you *** in the back door?
Old Feb 15, 2002 | 08:00 PM
jmax
I really think you should recheck your balance. Turn it slowly from left to right. Are you really wired correctly? If you are and it really sounds the way you say, it's almost got to be a phase problem.
Old Feb 15, 2002 | 08:15 PM
Evil Yak's Avatar
the more i think about it, the more i think you're right
the phase may be off, i'll check it out
i may just ditch the seperates and get a set of the
Eclipse Point Source coax's... I like having the tweeter
sit in the middle of the mid.
i do plan to seal up the door with some dynamat or
something of the sort..
Old Feb 15, 2002 | 09:00 PM
Micah95GLE's Avatar
Don't ditch the separates yet. Try bridge-mounting the tweeters across the mids. That's what I do. That gives you point-source response, and also the ability to aim the tweeters.
Old Feb 15, 2002 | 09:19 PM
jrr_206's Avatar
I had a similar problem with my car, it had to much bass and it just didn't sound right. I also have a Rockford amp. It was the gains that was ajusted wrong. They have to be ajusted to the head units voltage or something like that. I read it on the rochford fosgate web site. After I turned the gain down it, the bass was cleaner.
Old Feb 16, 2002 | 09:13 AM
Evil Yak's Avatar
well... i tried putting them there but
there just isnt enough room between the tweeter
and the mid...
anyway the first thing i do when i get the car back
is rewire all the highs, run 12 gauge for all the speakers
(got like 60 feet of it from work)
if that dont work, then ill try all the other options
Old Feb 16, 2002 | 11:08 AM
jmax
and the mid...
Label both ends of all wires before you run the wires under the carpet, behind dash, under seat, or whatever.
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
AT978
Aug 15, 2015 06:39 PM
MikesChevelle
Aug 9, 2015 11:50 AM
