box problem
Old Feb 15, 2002 | 01:16 PM
lowmax4's Avatar
box problem
I built a sealed box for two subs and a divider in the middle of the box. I hooked em up and it sounds like crap. when one sub goes in the other goes out, I sealed the box good so I don't know what the problem is
Old Feb 15, 2002 | 04:59 PM
maxima42's Avatar
how are the subs wired? It sounds like they are wired in parallel and the connections may be reversed on one of the subs.
Old Feb 15, 2002 | 07:48 PM
jmax
That was actually a very good description of "out of phase".
Old Feb 16, 2002 | 10:36 AM
lowmax4's Avatar
what is "out of phase"?, It's weird when I pull one of the rca's out the bass is louder with just one sub playing
Old Feb 16, 2002 | 10:44 AM
jmax
One woofer has the pos and neg connected backwards. Kinda like connecting two identical cars bumper to bumper and both drivers pushing the gas pedal. No matter how hard they try, in a perfectly linear scientific environment neither car will move. The net output of two woofers conected this way is the same. One cancells the other.
Old Feb 16, 2002 | 07:41 PM
KCTYPHOON
stupid question.. but do you have a wall inside the box seperating the chambers of the box for each sub? if you dont, thats why. the subs cannot be sharing the same airspace.
Old Feb 16, 2002 | 07:48 PM
jmax
- Yes they can, it's a sealed box. But it may magnify the problem when wired out of phase.
Old Feb 16, 2002 | 08:04 PM
KCTYPHOON
i thought they could only share the same airspace if they were on the same channel? thats what i was told when i had my box made for my typhoon with 4 12's.
Old Feb 16, 2002 | 08:22 PM
jmax
Thus a mono sub channel. As bass is non-directional, what other way would it be done?
Old Feb 17, 2002 | 04:51 PM
lowmax4's Avatar
Yes the two subs have their own air space. so if I wire thim up correctly the should be fine? also basiclly the two subs were working against each other and I was getting pretty much no bass? thanx guys
matts95max
Apr 23, 2025 10:44 AM
bumpypickle
Sep 20, 2015 08:22 AM
Stagnet04
Sep 14, 2015 11:28 PM
Colossus
Sep 9, 2015 05:46 AM
