Capacitor
Old Feb 18, 2002 | 08:24 PM
respect123's Avatar
Capacitor
I need to know how exactly do you charge up the CAP , I need step by step directions , I did exactly what the Instructions said and IT won't CHARGE up
PLEASE HELP
NEED TO HAVE MY JUICE!
Old Feb 18, 2002 | 09:40 PM
Matt93SE's Avatar
STFU n00b!
if you followed the directions with it and it didn't charge, then:
1. you're not doing something right
2. you've got a defective cap
I suggest taking it to an audio professional that knows what they're doing. caps aren't toys. they can weld a chunk of 4awg wire to your car in a flash (pun intended). nasty stuff if you screw it up.
Old Feb 19, 2002 | 03:43 AM
respect123's Avatar
Does anyone have professional directionals that could help me?
Old Feb 19, 2002 | 07:13 AM
Matt93SE's Avatar
STFU n00b!
your owners manual for the cap has professional instructions.
if you don't believe it, then read the FAQ at the top of the page and it'll tell you the exact same thing at every site you look at.
Old Feb 19, 2002 | 07:53 AM
respect123's Avatar
i must have a bad cap then , but i have it all hooked up and bass is working which it shouldnt if the cap inst charged so i dont get it??
Old Feb 19, 2002 | 12:38 PM
Matt93SE's Avatar
STFU n00b!
uhhhh, what size of cap, where are you installing it, and what are you wanting it to do?
you can use caps for many different things.. sounds like you may have things cornfused. one of us does anyway.
Old Feb 19, 2002 | 02:39 PM
respect123's Avatar
Have it installed on the power line from the battery to the amp,
Using it for dimming lights,
Didnt seem to charge correctly
Old Feb 19, 2002 | 09:27 PM
JAIMECBR900's Avatar
what makes you think the cap is not charged? Is it because you're lights are still dimming? What kind of cap is it and what size?
Old Feb 20, 2002 | 03:44 AM
respect123's Avatar
Yes the lights are still dimming , its a rockford fosgate ,5 farad cap ,
The resistor bulb never showed it charged
Old Feb 20, 2002 | 10:48 AM
You may have a bad cap, but I have never personally seen one be bad, specially since it sounds like it has never been charged before. Either way, make sure that you are connecting it correctly; positive from battery between amp and battery near the amp, and negative to same ground as amp. That should do the trick. If not, you either have a bad cap or have wrong wiring somewhere else as well and cap is not big enough to compensate for both problems.
Old Feb 20, 2002 | 11:01 AM
respect123's Avatar
You are suppose to ground it with the same ground as the amp?
I have it on another Ground , it says never to ground it with the amps ground in the instructions
mb1
Aug 26, 2002 01:15 PM
mb1
Aug 26, 2002 12:38 PM
DaveGrun
Jul 23, 2002 06:34 AM
D1NOnly34
Jun 21, 2002 02:38 AM
Nick97SE
Jun 3, 2002 09:07 PM
