capacitor finaly installed...pics!!!
Old Aug 24, 2002 | 02:09 PM
mb1's Avatar
mb1
well I finaly installed my capacitor. THANKS MING!!!
This must have been one of the simplest things I'v edone. All that was needed was a little wire rerouting and that was it.
http://members.directvinternet.com/~...tdocs/cap1.jpg
http://members.directvinternet.com/~...tdocs/cap2.jpg
http://members.directvinternet.com/~...tdocs/cap3.jpg
If you can't tell, it's where the jack goes.
Old Aug 24, 2002 | 02:36 PM
Blaximazx's Avatar
neat install but, if you get in an accident and a car hits you on that side
Old Aug 24, 2002 | 03:15 PM
nismo240sx's Avatar
caps dont explode, they just leak fluid...
eric
Old Aug 24, 2002 | 04:25 PM
Nathan's Avatar
Re: capacitor finaly installed...pics!!!
Very nice, thats a really good idea, maybe some carpeting or mirrors on the inside may finish it off nicely. Have you noticed a difference in the performance of your sound system after you installed it?
Nathan
Old Aug 24, 2002 | 09:00 PM
mb1's Avatar
mb1
Re: Re: capacitor finaly installed...pics!!!
Nathan
Thanks . I just got home from work, and I noticed my light dim alot less. The dimming is still there, but its like a small flutter compared to a prolonged drop in voltage.
Old Aug 24, 2002 | 09:06 PM
Sin's Avatar
Sin
Nice install. I'm glad everything went well. And as for the other poster's concerns about exploding, you shouldn't have to worry about that. HOWEVER, should you get hit there, the cap MAY discharge, and MAY cause sparks/fire, or short out some electrical components.
I had a friend who's burned some carpetting because his cap got knocked loose from it's mount.
All in all, I wouldn't worry too much about it. The odds of getting hit are slim, the odds of getting hit right there are even slimmer, the odds of you getting hit right there and cap damage occuring is even slimmer. But nonetheless, it is an added danger to your car.
Old Aug 24, 2002 | 09:23 PM
mb1's Avatar
mb1
Thanks for putting me at ease Sin. But I think if the cap came out ok from MAC's car after what it went through, I'll be fine.
Old Aug 25, 2002 | 06:21 PM
mb1's Avatar
mb1
here's a night-time pic of the cap and system.
does anyone have any tips on how I can tidy it up a bit? How do you all run your wires, and mount your amps?
Old Aug 25, 2002 | 11:49 PM
Nismo's Avatar
you can cut slits in the carpeting on the bottom and run the wires under the carpet. my amp is mounted behind the box so its not visible unless you open the arm rest
Old Aug 26, 2002 | 01:11 PM
mb1's Avatar
mb1
I though about that, but I have a solid plywood floor under there so I would have to cut into the wood.
Old Aug 26, 2002 | 01:15 PM
Nathan's Avatar
Where did you get that piece of plexiglass from? And where did you put your stock jack?
MidnightMaxima_22
Sep 12, 2015 06:02 AM
MaxedOut2g
Nov 19, 2001 08:07 PM
maxima42
Nov 15, 2001 02:14 PM
multiplexor
Nov 8, 2001 08:56 AM
AC439
Jul 8, 2001 11:25 AM
