Dual 4ohm speakers....
Old Feb 25, 2002 | 08:39 PM
twankz's Avatar
How would I wire a pair of dual 4ohm to put
out at 2ohm??
Old Feb 25, 2002 | 08:45 PM
mb1's Avatar
mb1
can't
Old Feb 25, 2002 | 09:03 PM
jmax
If you wire two 4 ohm coils parallel you will have a two ohm load. If you wire them series the load will be 8 ohms. Now if you have two of these speakers you can use the two 8 ohm loads for a total 4 ohm or 16 ohm load. Or you can use the two 2 ohm loads and get a 1 ohm or 4 ohm total load. The wiring method you use will depend on your amp and the sound quality/quantity you desire.
Old Feb 25, 2002 | 11:39 PM
Schmoo
For what it's worth, you can wire two in parallel to get 2 ohms, then wire another two in series to get 8, then wire those two sets together in parallel to get 1.6 ohms. Or, you can take 3 in series to get 12 ohms, then wire in parallel with the last to get 3 ohms. You probably shouldn't do either of these, but I thought I'd toss in the other possibilities.
Old Feb 26, 2002 | 09:00 PM
jmax
Sorry, I don't toss in possibilities that will blow one driver and underpower the other three.
Old Feb 26, 2002 | 09:41 PM
Schmoo
That's only assuming the speakers are all equal. But you're right, in that it was mostly just an academic exercise.
Apr 16, 2020 05:15 AM
bigdogsteve
Jan 31, 2018 04:18 PM
Robert Schneeweis
Jan 11, 2017 06:47 PM
RWCreative
Sep 21, 2015 11:01 AM
Justin Kroll
Sep 2, 2015 11:06 AM
