How to install aftermarket radio? Bose replacemet
Old Feb 27, 2002 | 08:34 PM
twankz's Avatar
I have read some replies that said that I need Nissan
wirings harness and antenna adapter, so exactly how do
I install these items with my aftermarket radio?
Old Feb 27, 2002 | 09:07 PM
Schmoo
Generally speaking, you hook up matching wires between the harnesses and then just plug it in. Regarding Bose replacement, check the recent posts here or do a search.
Old Feb 28, 2002 | 04:41 PM
ny96max's Avatar
Re: How to install aftermarket radio? Bose replacemet
i must have replyed to about 100 of the exact same posts regarding Bose and new headunits.
LAST TIME!!
1) buy a 95+ nissan harness
2) make sure you wire up BOTH blue wires on your Nissan harness to the remote line of the new headunit.
3) make sure you wire up BOTH black wires on the nissan harness to your new radios harness.
note* if the radio does not turn on, you will have to re-ground the main black wire from your Nissan harness to a solid piece of metal in the back of the centerconsole. On most 95+ nissans the ground wire in the factory harness is missing, hense you have to make your own ground!
5) DONE!!
Ant
Old Feb 28, 2002 | 10:20 PM
Schmoo
Note that 94 and older cars use a different harness. You didn't say what year you had.
6spd4dsc
May 9, 2022 12:30 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
MikesChevelle
Aug 9, 2015 11:50 AM
PhalC1
Aug 5, 2015 02:36 PM
