stealth & custom install help
Old Mar 19, 2002 | 10:29 AM
grunge's Avatar
Is there a website or magazine where i can view some stealth install setups. I am looking to redo my audio setup this spring and I want to go all out.
Is there aplace where i can order cusom molded pieces for a max trunk etc?
If i cant do stealth i would at LEAST like to get something more attractive than a box sitting in my truck.
If anyone has a sweet trunk setup post some pics so i can get some ideas.
thanks
Old Mar 19, 2002 | 10:52 AM
AndyXXL's Avatar
Re: stealth & custom install help
That's what I have in my max. http://www.jlaudio.com/stealthbox/maxima.html
Old Mar 19, 2002 | 11:10 AM
grunge's Avatar
Re: Re: stealth & custom install help
You can only have one of them and it already has a sub in it?
How do you like that?
Old Mar 19, 2002 | 11:34 AM
Whitemax's Avatar
Disco Biscuit
Yes it comes preloaded and you can only have 1. I love mine.
Old Mar 19, 2002 | 12:11 PM
grunge's Avatar
Im looking for more of a custom encloser for what i have... I had JL a while ago and wasnt impressed.
Old Mar 19, 2002 | 12:49 PM
AndyXXL's Avatar
Re: Re: Re: stealth & custom install help
Just one sub but it's more than enough for me, I love it.
Old Mar 19, 2002 | 03:27 PM
maximadave's Avatar
detailerdaveb@gmail.com
What didn't you like about it?
I've never heard one complaint about JL subs. What did your system consist of at the time?
Old Mar 19, 2002 | 03:46 PM
grunge's Avatar
I had them about three cars ago. I was using an alpine v12 amp to power them (300w?) had them bridged and one would blow out every month or so.
And they sounded muddy, they would play normal music fine, but when it came to a good bassline they choked and all the strings would bend together to be one muddy mess.
Im not sure what model they were, but they were the low ends.. i payed about 150 ea
Old Mar 19, 2002 | 04:17 PM
maximadave's Avatar
It sounds like your subs were underpowered. It is easier to blow a sub underdriving it more than overdriving it. Alpine amps are good but not strong in the bass department. You probably had a W3, go with the JL 250/1. It is matched perfectly to the W3.
Old Mar 19, 2002 | 04:49 PM
grunge's Avatar
No i had the proper amount of airspace and power. That is what i thought after listening to them for a while. I tried a diff amp... (xtant) didnt make a diff so i took the xtant back and stuck with the alpine until i could afford a new set of subs
Old Mar 19, 2002 | 04:52 PM
maximadave's Avatar
What series of JL subs did you have?
Old Mar 19, 2002 | 05:20 PM
grunge's Avatar
not sure... it was about 3 yrs ago
anyway any custom install ideas?
2 10" or 12" subs. 2 or 3 amp and 2 caps?
I want to make it all fit either stealth OR pro looking while still haveing spare access and plenty of trunkspace
Old Mar 19, 2002 | 05:42 PM
maximadave's Avatar
Here is some ideas for you............
pics courtesy of www.5thgenmaximas.com
http://www.5thgenmaximas.com/multimedia/multimedia.html
Dave
Old Mar 19, 2002 | 08:15 PM
PATRICK94SE's Avatar
Some time this week two JL 6W0s will find a home in my rear deck (Bottom mounted in custom boxes).....boxes bottom mounted to the deck
Old Mar 20, 2002 | 10:05 PM
bandera311's Avatar
I just got mine in today It sounds pretty damn. Alot better than my previous set up of 2 12" Pioneers. And there is so much trunk space I no longer have to haul bodies around in the back seat I need some suggestions on where i should mount the amp. The amp is relatively small, the footprint is 9.3" x 9.75" x 2.1" Any pics on mounting options would help thanks Chris
Old Mar 21, 2002 | 05:21 AM
AndyXXL's Avatar
Originally posted by bandera311
I just got mine in today It sounds pretty damn. Alot better than my previous set up of 2 12" Pioneers. And there is so much trunk space I no longer have to haul bodies around in the back seat I need some suggestions on where i should mount the amp. The amp is relatively small, the footprint is 9.3" x 9.75" x 2.1" Any pics on mounting options would help ) thanks Chris
My amp is mounted to the top of the trunk (not cover), it's kinda hanging upside down.
Old Mar 21, 2002 | 05:47 AM
grunge's Avatar
Sounds intresting... you should post pics when its done...
arent you worried about vibrational noise from the deck?
Old Mar 21, 2002 | 02:07 PM
zboy's Avatar
I almost mounted an amp that way in a different car I had, but the manual for the amp said not to do it cause it wouldn't be able to dissapate heat (all the surface area was on the top of the amp, and since heat rises..)
I guess it depends on the design of the amp though. Just woudln't want it to overheat.
-zach
Old Mar 21, 2002 | 08:46 PM
Matt93SE's Avatar
STFU n00b!
-zach
Make sure you've got correct cooling and you'll be okay..
My amps have the ability to be water cooled. I may or may not do it later, but I'm not messing with it right now. they're all right behind my subs, so they get tons of air moving over them to keep cool.
Mar 12, 2020 12:06 AM
MaxLife17
Jun 27, 2019 01:37 PM
t6378tp
Sep 29, 2018 04:27 PM
0m3nc0w
Sep 11, 2015 05:21 PM
Johnny9595
Sep 3, 2015 05:18 AM
