Adding Amplifier to Stock Bose Head Unit
Old Apr 21, 2002 | 05:08 PM
bbwonder25
Does anyone know if it's possible to connect an amplifier and subwoofer to the existing Bose Head Unit of a 4th Generation Maxima?
Old Apr 21, 2002 | 05:30 PM
i30dude's Avatar
yes,it is my friend.
Old Apr 21, 2002 | 10:17 PM
iregula's Avatar
yes and no
you have pre amps in all the speakers so you have to reroute all your wiring! what a pain
Old Apr 21, 2002 | 10:36 PM
Paradoxish's Avatar
Re: Adding Amplifier to Stock Bose Head Unit
*cough* FAQ *cough*
Quick! Go! Read before a moderator comes around and slaps you!
Old Apr 21, 2002 | 10:37 PM
xHypex's Avatar
The easiest way is to just tap the rear speakers and use a convertor. I can't think of the name off the top of my head, but my system is wired this way. It's not the best method (as compared to running from the headunit), but if you just want to add a single sub or two it does the job. I have some pictures if you want them.
-hype
Old Apr 21, 2002 | 11:12 PM
ericdwong's Avatar
Yes, please read the FAQ. I did an extensive writeup about this.
Old Apr 22, 2002 | 05:02 PM
Yukondiver's Avatar
Check out AudioLink for the converters. I'm using the PD-4.
http://www.linkmeup.com/home.htm
Old Apr 22, 2002 | 06:55 PM
xHypex's Avatar
I don't know why this thread was moved since it is relevant and not super audio related, but whatever. Here's the way I did everything.
Hope it helps
http://bba01.bus.utexas.edu/Matthew.Quon/max.htm
-hype
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
