When using a Capacitor--->>
Old Dec 3, 2000 | 09:06 AM
Washington DC Maxima's Avatar
do I choose it by how many peak amps my amp has or by the RMS of my amps??
Old Dec 3, 2000 | 10:26 AM
Micah95GLE's Avatar
Ideally, you should get a birth sheet or bench test for the amp so that you know exactly how much it is really putting out (the manufacturer's specs are probably underrated or overrated). Then you would get 1 farad for every 1000 watts.
Old Dec 3, 2000 | 11:29 AM
Synki's Avatar
I agree with Micah, check the specs on how much power you are really pushing. Remember 1 farad is good for 1,000watts, in my mind that is complete bull****. If you chop the caps open, they are only half full. In reality they are more like a .5 farad. If you are running 1,000 watss, use a 1.5 farad. When i was pushing over 2500 watts in my Maxima i was running four 1 farad caps adn they didnt help dimming much either. Remember to charge the cap before you use it.
Old Dec 3, 2000 | 02:06 PM
Ok, I only run 550 RMS --->>
with my Fosgate Amps nothing huge.. so should I get 1/2 Farad or 1??
Old Dec 3, 2000 | 02:09 PM
Micah95GLE's Avatar
What model do you use for the sub? The sub amp is really the only one that needs capacitance, since higher frequencies don't draw much power.
Old Dec 3, 2000 | 02:35 PM
Synki's Avatar
For 550rms i would just stick to a 1 farad. LIke Micah said, for other amps, a cap isnt required due to the fact they dont drain like sub amp. Good luck. As far as brand. go Stinger, PG, or Lightning Audio. Lightning Audio is the best but also most expensive. When i work at my shop, i got mine for $70 each for 1 farad. Expect them to be anywhere from 90-160 for a 1 farad.
Old Dec 4, 2000 | 06:34 AM
I use the 250a RF -->>
So my cap should be after my power distribution block going toward my Sub Amp not before for both amps.. I bought a RF 1/2 Farad Cap while I was in ATL a few months ago I notice Synki didn't mention that brand is it cheap??
Old Dec 6, 2000 | 01:12 PM
jmax
Another thing to remember about Caps is that as they age their ability to store electricity diminishes. So if you get a 1 farad cap it will last longer than a 1/2 farad cap. But on the other hand you may be in the market for a whole system upgrade by the time it degrades ot that point.
Old Dec 6, 2000 | 03:36 PM
Synki's Avatar
Re: I use the 250a RF -->>
You can get a 1 Farad Cap at a SOund City for 89 each. THis is the Stinger SC1FI 1 Farad Cap. The number for a black color one is: 25179 If you want a white colored cap, its: 28615 I'm not sure if there are any near you but they do have a website. You can order toll free @ 1800-432-0007
JacksMax
Mar 2, 2001 02:31 PM
