removing rear stock bose speakers help....
Old Jun 9, 2002 | 12:49 AM
FlAWD96SE's Avatar
how do you remove them? i cant figure it out nd im not about to waste $50 on that when i can do it
ne help?
Old Jun 9, 2002 | 03:35 AM
carnal_c30's Avatar
Former Sponsor
Re: removing rear stock bose speakers help....
ne help?
to remove the front ones you have to take off the door panels and just take the screws out its easy as pie and disconnect the harnesses
the rear speakers, remove the grille and unscrew em 4 screws in each... easy as pie
Old Jun 9, 2002 | 03:40 AM
Iron Lung's Avatar
ne help?
1. Take out lower portion of the rear seat(what you sit on) there are two pull tabs.
2. Take out the upper seat portion by removing the two 10mm bolts at the lower corners of the seat. Also, in the middle(where the armrest folds down) there are two more 10mm.
3. push the upper portion of the seat up to remove it.
4. Take out the rear deckboard by pulling up. It is held on by trim tabs so try to find the closest ones and pop them out, moving your way to the back.
5. You will see the speakers now. The bolts i believe are 7mm. You should know what to do from then on.
Old Jun 9, 2002 | 04:19 AM
carnal_c30's Avatar
Former Sponsor
Re: Re: removing rear stock bose speakers help....
hmmm you have to remove the rear seats? maybe i missed that, all i remember moving the rear seat for was to route the wires for my sub... removing the stock speakers was a cinch
oh well n/m
Old Jun 9, 2002 | 04:23 AM
Iron Lung's Avatar
Re: Re: Re: removing rear stock bose speakers help....
oh well n/m
Did you have the bose? Or maybe they did things different in 99. My grill was bolted down from underneath the rear deckboard.
Old Jun 9, 2002 | 05:11 AM
carnal_c30's Avatar
Former Sponsor
Re: Re: Re: Re: removing rear stock bose speakers help....
I took out my stock GXE system on my '97 that was VERY simple, I also stripped a Bose system out of a salvaged '96 Max I think there are screws underneath the rear deck holding in the grilles but cant u access them from the trunk? and after that just the 4 screws on each speaker.
I did the install/strip along time ago and the rear seats were out for other reasons so i cant be sure ur probably rite
oh well hehe n/m FIAWD96 probably gets the picture now
Old Jun 9, 2002 | 08:39 AM
blizz20oma's Avatar
I'm so hood
In the (Crutchfield, I believe) manual I got from a fellow .org'er, the instructions to removing the rear speakers on a 4th-gen began with removing the rear seats...
Old Jun 9, 2002 | 04:09 PM
carnal_c30's Avatar
Former Sponsor
I stand corrected! thanks!
Old Jun 9, 2002 | 04:18 PM
SilverMax98's Avatar
I just finished replacing my entire system in my 98 SE, you do have to remove the rear seats to get the back speakers....It's really really easy, as stated above, those directions Iron Lung gave are right !
Old Oct 27, 2011 | 08:32 AM
Psychadelic23's Avatar
I just got a '99 GXE and have already blown the rear stock speakers. CRAP!! Do any of you have pics showing how this is done to remove the stock speakers? Or is it just as easy as following the previous isntructions?
Old Nov 8, 2011 | 09:50 AM
Wizxon's Avatar
http://www.vqpower.com/v2/articles.php?article_id=39
This is for the 4th generation maximas. I believe this is for Bose though.
Old Jun 18, 2012 | 11:27 AM
quickspe3dmax's Avatar
I am trying to remove my back speakers in my 95...do i have to take the side tower panel things off where the back seat bealts go into or can i just lift the deck?....there is glue there...will i have to replace the glue???
Old Jun 24, 2013 | 05:43 AM
Luvmy 96's Avatar
Any electronics involved?
I've had the front door panels of and see there are amps (and crossovers? on the front spkrs.(96 stock Bose system) Is that true of the rears also? if so wouldn't that require special replacement spkrs?
Old Jun 25, 2013 | 02:04 PM
djfrestyl's Avatar
Suspension Yoda
In the 4th gen each speaker has a small dedicated amp mounted with the it.
No, it wouldn't require special speakers - just mounting brackets. You'll have to replace your HU if you replace your speakers - as the level of the output signal coming out of the OEM HU would not be sufficient to power your aftermarket speakers.
jskirwin
Jun 8, 2016 08:49 AM
vingodine
45
May 21, 2016 12:46 PM
melteye
May 16, 2016 12:02 AM
Huttig2009
Sep 25, 2015 03:31 PM
MikesChevelle
Aug 9, 2015 11:50 AM
