Escort ZR3 radar jammer now available!
Old Jun 14, 2002 | 09:07 AM
maximadave's Avatar
detailerdaveb@gmail.com
The all-new Laser Shifter ZR3
Ultimate Laser Defense System
What is LASER?
LASER technology used to measure speed is actually called LIDAR, which stands for Light Detection and Ranging. This light is invisible to the human eye, and is very difficult to detect.
How do LASER Guns work?
LIDAR guns project a beam of invisible infrared light. This light, or signal, is transmitted in a series of very short pulses, which move in a straight and narrow line to the target vehicle. Once this signal hits your vehicle, the light bounces back to the LIDAR gun. Your speed is then calculated by measuring the change in distance over time.
How widespread is LIDAR?
It's estimated that over 25,000 LIDAR guns are in use today. This number is growing every day. In some areas it has become the standard issue for law enforcement.
How serious a threat is LIDAR?
LIDAR is a newer technology for measuring speed than conventional radar, therefore, you may not encounter it on a daily basis. However, LIDAR is much more accurate, and because the signal (beam of light) is much narrower, it is extremely difficult to detect. In fact, some of the best radar/laser detectors may not provide enough warning to adjust your speed.
How do I defend myself against LIDAR?
Introducing the new Laser Shifter ZR3 - the ultimate laser (LIDAR) defense system from Escort. The new Laser Shifter ZR3 is equipped with a total of three (2 front, 1 rear) laser "Shifters." These highly sensitive transceivers detect the presence of LIDAR, and respond with a pulsed laser signal in order to "Shift" or confuse the targeting LIDAR gun.
Do I need front and rear LIDAR protection?
YES! Law enforcement officers can target your vehicle from the front or the rear. Some speed traps are designed with the officer positioned on an entrance ramp, providing no visual indication of their presence. The rear sensor of the Laser Shifter ZR3 protects you from this kind of ambush.
Is Laser "Shifting" safe?
YES! The Food and Drug Administration regulates the use of Laser. The Laser Shifter ZR3 is safe, and accurate against targeting laser guns. However, this type of product may be limited or prohibited in some jurisdictions. Check your local laws before using.
What control do I have over the Laser Shifter ZR3?
The Laser Shifter ZR3 is packed with useful features including front and rear indicators, volume control, mute, and manual "receive only" mode (patent pending). Since some of the LIDAR guns are equipped with "jamming codes," our exclusive "receive only" mode allows you to disarm the shifters during an alert - minimizing attention from the targeting officer.
Can I use the Laser Shifter ZR3 with my current radar/laser detector?
Yes. In fact, Escorts's exclusive design allows you to "link" the new Laser Shifter ZR3 to the award-winning Passport 8500 - providing the ultimate protection against all forms of radar and laser encounters. This combination of detection and "Laser Shifting" is the best protection available. Click here for more information about linking the ZR3 and 8500.
Comes Fully Equipped
ZR3 comes complete with a comprehensive owner's manual, installation instructions, two front laser transceivers, one rear laser transceiver, in-car display controller, remote mute button, 12-volt interface with modular connections, complete wiring harnesses, mounting hardware, and Link Cable for Passport 8500.
Limited One Year Warranty
Front and Rear Mounted Laser Transceivers
Plug-in Installation using Modular Connections
Front and Rear Indication
Automatic Brightness Control
Remote Mute / Manual "Receive Only Mode"
Self-Diagnostics with Error Indication
Designed to "Link" with Passport 8500
$499.95 suggested retail price installed
Performance Certified
94% Effective
Speed Measurement Labs
Professional Installation Required
The Shifter ZR3 is sold exclusively through the same high-performance car dealers and car audio specialists as the Passport SR1. Call 800-964-3143 or use the Shifter ZR3 dealer locator below to find a dealer near you.
Shifter ZR3
Features and Specifications
Operating Band
* Laser 904nm, 33 MHz Bandwidth
Laser Detection
* Quantum Limited Video Receiver
* Multiple Laser Sensor Diodes (6F, 3R)
Laser Transmitter
* Multiple Laser-Shifting Diodes (16F, 8R)
Display Type
* Hi-visible LED indicators
* Automatic Brightness Control
Power Requirement
* 12VDC, Negative Ground
Dimensions (inches)
* Display/Controller: 4.2 x 1.4 x .55
* Front Laser Units: 4.65 x 1.8 x .80
* Rear Laser Unit: 6.0 x 1.0 x .65
The Shifter ZR3 and Passport SR1 were specifically developed as products to be sold and installed by an elite network of dealers - all qualified to provide professional installation.
Old Jun 14, 2002 | 11:18 AM
soundmike's Avatar
Very sound, Mike
Thanks for the info Dave! Btw, if you could - please read this post and LMK what you think. Thanks
Old Jun 14, 2002 | 11:29 AM
maximadave's Avatar
I replied to your post on nissanx.com
Tweeter doesn't carry the 7301. Wait til next month when the new models are released.
Dave
Old Jun 14, 2002 | 11:34 AM
soundmike's Avatar
Very sound, Mike
Thanks for the heads up Dave!
JRod28
Feb 4, 2016 11:07 AM
BRIGBOY
Mar 2, 2001 03:27 PM
JimW
Dec 21, 2000 01:12 PM
steveyang
Nov 9, 2000 08:07 PM
LeoB
Sep 17, 2000 04:49 AM
