Need help with subwoofer wiring
Old Jun 17, 2002 | 01:34 PM
GOD's Avatar
GOD
I have a 1999 automatic maxima and I can't for the life of me figure out how to access the engine compartment from inside the car so I can run my power wire from my amp (under the driver's seat) to the battery in the engine. Any help would be welcome.
Old Jun 17, 2002 | 01:42 PM
Str8ridin's Avatar
With all do respect, GOD, don't you already know everything?
Old Jun 17, 2002 | 01:43 PM
Ginuwin3112
Ok...jack the car up and remove the front left wheel..remove the plastic fender cover thing..just run the power amp wire through one of the holes behind the left strut tower into the inside of the fender, i ran my wire through the wire grommet of the door harness. then it leads to right under the fuse box under the dash..no cutting whatsoever..then from there run it to the back. i will post pics tonight
Old Jun 17, 2002 | 01:44 PM
GOD's Avatar
GOD
Actually, I am just a DemiGOD, so I know I can drill a hole through the firewall, but not any alternate methods.
Old Jun 17, 2002 | 01:45 PM
GOD's Avatar
GOD
Thank you! I'm not sure I'm gonna start til you post pics, but when you do, I'll go for it!
Old Jun 17, 2002 | 01:49 PM
Ginuwin3112
NOO dont cut any holes. holes are bad
Old Jun 17, 2002 | 02:13 PM
GOD's Avatar
GOD
okay, i have the wheel off, how do i get that plastic panel off? i took the screws off, but theres these other things holding it in place and i cant get them off...
Old Jun 17, 2002 | 02:20 PM
Ginuwin3112
i didnt know how to get them off either..i just broke em off, but after i broke em off i learned that u need to pull out the middle part (looks like a little screw), then pull the whole thing out..i just got new ones at autozone.
Old Jun 17, 2002 | 02:33 PM
GOD's Avatar
GOD
ok, i got the plastic panel off, now i cant get to the car itself cuz there is some wierd rubber conforming to the wires that are already going in there. I was wondering if there was a way to squeeze my power wire in with those wires or something...
Old Jun 17, 2002 | 02:51 PM
GOD's Avatar
GOD
FINISHED!!! THANK YOU!!!
Old Jun 17, 2002 | 03:01 PM
MrGone's Avatar
Hey,
I know im late but i poked mine through the hood release, btw, by the name choice i am led to believe you took this as a one stop "shop", ah anyway, keep coming back, were glad to help you, the search is your friend though, thats why some werent to helpful, weve gone over this a bunch, i did it too
anyway, we love pics and welcome to the club.
MrGone
Old Jun 17, 2002 | 08:15 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Ummmm..why exactly are holes so bad?
Old Jun 17, 2002 | 08:50 PM
Ginuwin3112
Well i guess it degrades the structural integrity of the chassis..
Old Jun 17, 2002 | 08:52 PM
Pearl96Max's Avatar
A quarter to half inch hole in the firewall?!?!
Old Jun 18, 2002 | 10:07 AM
itsgt's Avatar
Re: Need help with subwoofer wiring
after you guys get the wire inside the car, if i need to run the wire all the way to trunk...should i just run it under all the carpeting? or is there better way?
Old Jun 18, 2002 | 11:36 AM
time2reup's Avatar
Re: Re: Need help with subwoofer wiring
Yep pull up your door sills, and the the carpet comes up pretty easy, make sure you isolate your power wire from the rest...
Old Jun 18, 2002 | 09:30 PM
Ginuwin3112
if you have limited space in your trunk you can mount your amp under one of the front seats then its just wires that are running to the back..saves alot of space!
Old Jun 18, 2002 | 10:06 PM
Pearl96Max's Avatar
BUT you need to make sure your amps can "breathe".
Old Jun 18, 2002 | 10:51 PM
Ginuwin3112
I dont think they will have any trouble breathing its not like its airtight under the seat
Old Jun 19, 2002 | 05:29 AM
Pearl96Max's Avatar
No you are right it is not airtight, but regardless. Depending on the amp and when it is reaching its peak power. Also if it is being played continuously it will tend to heat up. If the amp has a built in fan it should be fine, if not it MAY overheat. I am not saying it will, but that is can. Amps do need proper ventilation.
Old Jun 20, 2002 | 10:16 PM
Bad97MaxSE's Avatar
Youll be fine drilling the hole in your firewall, i did
Old Jun 21, 2002 | 02:15 AM
MrGone's Avatar
before drilling, you may consider what i said though, it will save time and depending where you drill, look better.
go through the hood release hole, its pretty big.
also the best way to get around amp breathing or overheating problems is to have a degree in AMD Overclocking, preferably be in the 400mhz + FSB club
later guys
MrGone
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
