Where to pick up turn-on lead for amp?
Mod her. Ate her.
Where can I pick up a turn-on lead to turn on an amp? I would rather have one that is on only with the HU, but will take any 12V switched, if i have to. How do the BOSE amps know to turn on? Are they on any time the car is on? If I can use the BOSE turn-on lead, which is it on the REAR speakers?
Thanks!
Thanks!
Originally posted by Subw00er
how do I get the non bose radio out on a '02 max?
Take out the ashtray/felt pocket and you will see a single screw which needs to be removed. Use a magnetic screwdriver if possible.
There will be Two screws that hold the Radio/AC module in place right under and behind where the ashtray was. You will need to remove these screws.
Here's the scary part. You have to gently, but firmly lift up on the bottom of the Radio/AC module, pulling it outward toward you so that it pops the top AC vent assembly loose. Don't lift it too far out, but just enough to loosen the Air Vent. There's really nothing to break (I hate to say that), but be careful, none the less.
Once the airvent is out (it has no screws) you will see two more screws, which, when removed, will allow the entire Radio/AC assembly to come out.
From there, just be careful not to scratch your dash by placing towels all around, and unplug your cables from the AC and Radio components.
Good Luck, let me know if this helps...
DC_Juggernaut
09-28-2015 04:07 PM
Pied
09-26-2015 03:29 PM
