is kicker any good?
Old Dec 7, 2000 | 08:53 PM
rambo91145's Avatar
my friend has a pair of kicker impulse 4" i was thinking of putting these in my doors. will they fit? will it sound good? i have a 94. thanks
Old Dec 7, 2000 | 08:57 PM
metallic97gxe's Avatar
Master Will
Are they
Kicker is good but get the comps,the impulse's are ok but I would not have them
Old Dec 7, 2000 | 09:05 PM
rambo91145's Avatar
Re: Are they
whats wrong with them? do they have poor sound quality? i guess these are the low grade of kickers??i am not into a huge expensive system, just want something that sounds good, and you dont think these would sound that good huh???
Old Dec 7, 2000 | 09:20 PM
Synki's Avatar
Kicker is good but they make better subs. I would rather get infinity or something along that line of better sound speakers. You can fit bigger then 4" in the doors i know.
Old Dec 7, 2000 | 09:24 PM
Master Will
Re: Re: Are they
They are weak in terms of power handling,they sound good but you can't put much power/amp on them,you can get oversized 6 1/2" in your doors check my page in my sig to see what I have click on my name WILLIAM
Old Dec 8, 2000 | 05:23 PM
Micah95GLE's Avatar
4s won't have any midbass, so they'll sound bad. You need 6.5s.
Old Dec 8, 2000 | 09:04 PM
rambo91145's Avatar
will 6 1/2s fit? what is in there now?4by6s? i havent taken off the kick panel yet. so i guess 4s arent the way to go huh? what are 4s good for or meant for?(sound wise) i have 3/4 in. tweets im mounting somewhere else. i am going to use 6by9s to help fill in on mids. i was plannning on running my door speaker off head unit (40wattby4) or have a 40by2 watt amp. also considered infinity 4by6 replacements. any help/suggestions would be appreciated.
rambo91145's Avatar
Old Dec 8, 2000 | 09:38 PM
Micah95GLE's Avatar
Get an amp for the front door speakers and power the rear speakers with the HU. Make sure that you get 6.5s for good midbass up front.
Old Dec 9, 2000 | 01:03 AM
Matt93SE's Avatar
STFU n00b!
If you want something decent that will simply drop-in, then look at the infinity 4x6 speakers.
if you want more midbass up front or don't plan on adding subs later, then I'd say go with 6.5" speakers.
most audio shops will easily install them for you with minimal extra charges, but some will try to bend you over.
Either that, or you can make your own adaptor plates to git the 6.5" in there.
again, if you want simple & sweet, just pick up some 4x6 speakers that will drop right in.
you don't NEED an amp on them, but Id' highly recommend one if you want to get good sound out of them.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
cruce91
Sep 20, 2015 10:23 AM
MaxLife17
Sep 8, 2015 02:36 PM
