Alternator gone what to do read plz
Old Jul 5, 2002 | 02:06 PM
madmax97's Avatar
Ok sittin in traffic for about an hour system on and and neons on get out of the mess and then **** starts happening...is this spose to happen is everything drawing that much...what precautions can i take or how can i stop this from happeing i was thinkin of aftermarket alt,yellow top battery and cap for system any otherinfo thanks
Old Jul 5, 2002 | 03:08 PM
jmax
Proper wiring is the most important item. Starting with good grounds and good connections. After wiring everything right a cap can save the alt some headaches. A bigger battery is simply a strain on the electrical supply, in the car that means the alternator. Unless you sit with the engine off listening to music the stock battery should be fine. A single bad ground can kill an alternator. Any ground in the car, from a dome light or other accessory to the battery ground.
How much current does your stereo draw - what is the fuse rating on all amps combined? How are the lights wired and how much current do they draw?
Old Jul 5, 2002 | 06:06 PM
Llfe's Avatar
who wired the system for u?...well having a cap will definitely help...it'll help with lights dimmin also
Old Jul 5, 2002 | 10:57 PM
MrBlank's Avatar
There is a recall on all 97 maximas alternators. Do a search or check the general forum
Old Jul 6, 2002 | 08:30 AM
jmax
http://www.nhtsa.dot.gov/cars/probl...calls/Index.cfm
Okay, I did the search and above is the link. I guess the rumor I heard earlier in the week was true .
TallTom
57
Oct 14, 2025 05:16 PM
maxinout93
Oct 31, 2015 02:04 AM
homewrecker
Sep 24, 2015 07:01 PM
