FS: Alpine MRA-F350 Theater Amp
For sale is an Alpine MRA-F350 Theater amp. The amp is all digital 5 channel amplifier. It has Dolby Pro Logic, DTS, Dolby Digital. All the bells and whistles. The only down side is that it will work only with certain Alpine HU such as the W200, W205, DVA-9860, DVA-9861, DVA-9960 and others. It is touchscreen capable. Below are the following specs from Alpine.
FEATURES
• Crossover (HP/LP)
• 5 Channel Operation
• Adjustable Crossover (HP/LP)
• Auto Overcurrent Protection
• Bass Engine®
• Bass Management
• Cross-Vented Chassis Design
• DC-DC PWM Power Supply
• Darlington Bi-Polar Outputs
• Discrete Pre-Amp Stage
• Gold Plated Power Screw Terminals
• Gold Plated RCA Jacks
• Gold Plated Speaker Terminals
• MOSFET Power Supply
• Manual Time Correction
• Non-Fading Pre-Amp Output
• Parametric Equalizer
• Phase Selector
• STAR Circuitry
• Solid Copper Bus Bars
• Subsonic Filter
• Thermal Managment Processor
• Top Mounted Blue LED Power/Status Indicator
• Triple Darlington in Push-Pull Configuration
SPECIFICATIONS
CEA-2006 Power Rating (40hm@14.4V = 1%THD+N), S/N 100dBA (Ref. 1W into 4Ohm):
•50W x 5 (0.08% THD)
RMS Power (at 12V THD+N,20Hz-20kHz)
• Per channel into 4 ohms, S/N 100dBA (Ref. 1W into 4Ohm): 50W x 5 (0.08% THD)
Bass Engine®
• Crossover Frequency Adjustment : 20 - 200Hz: 1/3 oct step (1/2ch, 3/4ch), 20 - 400Hz: 1/3 oct step (5ch), 20 - 200Hz: 1/12 oct step (6ch, LP/OFF)
• Crossover Network : 6/12/18/24dB
• Parametric EQ (Bands) : 17 (Front: 5, Rear: 5, Center: 5, Subwoofer: 2)
• Parametric EQ (Level) : ±9dB
• Parametric EQ (Width (Q)) : 0.5/1/2/3/4/5
• Parametric EQ Frequency : 20 - 20kHz (1/6 oct step)
• Subsonic Filter (Selectable) : 20 - 50Hz, 1/6 oct step, slope: 6/12/18/24
General
• Heat Sink (WxHxD)mm : 285mm x 60mm x 242mm
• Input Impedance : 10k Ohm
• Input Sensitivity (V/at 10k ohms) : 0.85V (Ai-NET)
• Power Requirements : 14.4V DC (11V to 16V)
• Signal to Noise (S/N) : 80dBA
Herre is a pic of the actual amplifier I am selling:
The amp sells an average on Ebay for $300 not shipped, I am selling the amp for $225 shipped, OBO and I will take trades for some lowering springs plus cash. I have all original paperwork and box.
Oliver
FEATURES
• Crossover (HP/LP)
• Bass Engine®
• Bass Management
• Phase Selector
• STAR Circuitry
• Subsonic Filter
SPECIFICATIONS
Bass Engine®
General
Oliver
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
popdedop
Sep 11, 2015 11:17 AM
