Kicker Sx600.2 500 Watt Rms Amp
Old Jul 8, 2007 | 05:12 PM
Scooobay's Avatar
Selling this kicker amp. Amp works fine, Menu on amp does not display but the memory presets are still set so LPF is still accessed. Retails for $900...Im selling it for $250. Pickup only or i'll meet 1/2 way somewhere not too far. Cell is 908-635-2436. Trying to sell it ASAP. Here are pics and specs:
Specs:
Product Description:
* Kicker SX600.2 2-Channel Amplifier with DSP
* 32-Bit User-Programmable Digital Signal Processing
* RMS Power Rating:
o 138 watts x 2 channels @ 4 Ohms
o 275 watts x 2 channels @ 2 Ohms
o 550 watts x 1 channels @ 4 Ohms Bridged
* UltraMatch Gain Structure, single-band parametric KickEQ (Variable Gain, Boost, and Q), and crossovers ( Variable High and Low-Pass Filters )
* SAMS (Stereo And Mono Simultaneously)
* ISIS (Indicate Status & Input Settings) Interface
* BLAST Port (Bass Level And Signal Transfer) Provides Remote Bass Level Control and control signal transfer between multiple SX amplifiers
* Kompressor
* Adjustable Phase Control: 0 - 180°
* EndKaps: Cast aluminum, custom, removable covers to protect and hide all your wiring connections to the amplifier
* SickBay and On Board Diagnostics
* Frequency Response: 20 Hz - 200 kHz
* Variable Input Sensitivity: 1V / 2V / 4V / 8V / 16V
* Signal-to-Noise Ratio: >100 dB
* MOSFET Power Supply
* RCA Outputs: 1 Pair
* Remote Gain Control
* Fan Cooling
* Dimensions (With Endcaps): 22-1/2" L x 10" W x 2-1/2" H
* Authorized Internet Dealer
* 2-year Manufacturer's warranty
Amplifier Specifications:
* Amplifier Class N/A
* Number of Channels 2
* RMS Power (4 ohms) 138 watts x 2 channels
* RMS Power (2 ohms) 275 watts x 2 channels
* RMS Power (1 ohm) Not Stable
* Bridged RMS Power 550 watts x 1 channel
* Peak Power Output 1100
* Minimum Impedance Unbridged 2 ohms
* Minimum Impedance Bridged 4 ohms
* THD at Rated RMS Power 0.2%
* Speaker Level Inputs No
* Amp Preamp Outputs Yes - 1 pair
* Built-in Crossover Yes - HP / LP
* High-Pass Crossover Frequency 10 - 16 k Hz
* Low-Pass Crossover Frequency 30 - 20 k Hz
* Subsonic Filter N/A
* Signal-to-Noise Ratio >100 dB
* Channel Separation N/A
* Bass Boost -18 -- +18 dB
* Bass/Gain Remote Yes
* Fan Cooled Yes
* Fuse Rating 80A
* Warranty 2-year Manufacturer's
Old Jul 13, 2007 | 06:02 AM
Scooobay's Avatar
Bump. Reasonable offers will be considered
Old Jul 15, 2007 | 01:39 AM
Scooobay's Avatar
Bump new price $250
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
