(NY) FS: 2 12" Kicker L7's w/ SSL AMP, Audison SRX4 Amp
Buyer of the car decided doesn't want a system with it. So ive decided to throw it up for sale.
2 12" Kicker L7's (older silver style) in a sealed box.
SSL monoblock AMP- Rated @ 1700watts RMS
One Ohm Stable Mono-Block
· Strapping capability: Strap two amps together
for twice the power (2 Ohm stable)
· Variable low pass crossover: 50 -150Hz
· Variable subsonic filter: 15 - 40Hz
· Variable 0 to +18dB Bass Boost
· Phase shift selector: 0 or 180º
· Variable input gain control
· Input voltage sensitivity selector
· Power and protection LED indicators
· Illuminated blue logo
· Thermal, overload and speaker short protection
· RCA Line Level inputs
· RCA Line Outputs for system building
· Chrome plated RCA connectors and screw terminals
· Remote subwoofer level control
· Frequency response: 50Hz - 150Hz (+/- 3dB)
Max power 1 ohm 3000W X 1
Max power 2 ohm 2200W X 1
RMS power 2 ohm 1700W X 1
RMS power 4 ohm 1200W X 1
Signal-to-noise ratio
105db
THD at RMS output
0.01%
Damping factor
125+
Dimensions
(11-3/4” W x 3” H x 12-1/2” L)
$400, No shipping please.
Also up for grabs is a Audison SRX4 4-Channel Amp
Audison SRX 4 Amp
4 Channel
Front/rear or front/sub amplifier with built-in crossover. Front channels filter can be hi-pass or full range, rear channels one can be hi-pass, lo-pass or full range. SRx 4 can be used as a 4/3/2 channel amplifier. When you choose 2 channel configuration (left/right), you can use hi-pass, lo-pass or full range functioning. There are 'speakers-in' front/rear inputs and a bypass output.
* RMS Outputs:
o 4 x 60 Watt at 4-ohms
o 4 x 85 Watt at 2-ohms
o 2 x 60 + 1 x 190 Watt at 4-ohms
o 2 x 85 + 1 x 170 Watt at 2/4 ohms
o 2 x 170 Watt at 4-ohms
* Bridgeable 4 / 3 / 2 Channel Output
* 2 Ohm Stable
* High Level Speaker Input
* Built in Cooling Fan
* High Pass Crossover
* Low Pass Crossover
* RCA Input
SRX-4 - Audison SRX4 4 Ch Amplifier
Great amp to power your interior speakers: $200
Edit: Noticed a crack in the end cap of the amp, DOES NOT affect playability.
Asking $150 instead.
105db
THD at RMS output
0.01%
Damping factor
125+
Dimensions
Audison SRX 4 Amp
4 Channel
* RMS Outputs:
* 2 Ohm Stable
* RCA Input
popdedop
Sep 11, 2015 11:17 AM
