Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
upgrading / changing FRONT sway bar?????
Old May 6, 2005 | 05:56 PM
Spaniard's Avatar
Anybody do this? Should I??? Whats the deal? If its a good idea, where would I get one!??
I know that for autocross, its not desirable for turn in- BEJAY, Im thinking of your comment that you are running fastest with it disconnected. However, for high-speed turns would it be a positive?
Basically, anyone got feedback on this? Thanks-
Old May 7, 2005 | 02:21 PM
$tillenmax2k
Increase front-end mechanical grip, and stiffen the sway bar. I had this done to my car by a local maxima tuner, but your car must be lowered in order for it to work.
Old May 7, 2005 | 04:27 PM
Spaniard's Avatar
Sounds pretty good- Im on eibach springs so low enough I should think. When you say stiffen the bar you mean buy a larger diameter bar, is that correct? I appreciate your advice.
Oh, and on the off chance, do you know the stock size of the bar?
Old May 9, 2005 | 05:01 PM
z32drifter's Avatar
well more front bar is going to increase understeer...... I would be game if someone made a adjustable set for the Max..... I have never seen a front bar listed for the Max .. however if the adjustable rear bar is stiff enough to compensate for a larger front bar.. it would be useful to control body roll on the front end ....
Old May 10, 2005 | 10:36 AM
BEJAY1's Avatar
Conecarver
For track speeds it's probably a good idea to keep it or beef it up. Decreasing front roll resistancne is roughly equiv to increasing rear roll resistance ie. (adding a huge rear bar which might provoke oversteer conditions). IIRCboth the Stillen PPG car and the Motorola Cup cars kept their stock FSB's.
If you do go with a larger bar I'd do a buyin on a smaller one at the same time to test. Try calling Saner for latest pricing.
http://www.sanerperffab.com/
Old May 10, 2005 | 08:29 PM
irish44j's Avatar
retired moderator
ummm....why bother with a larger FSB? Get one of these instead:
http://www.mattblehm.com/suspension.html
Old May 10, 2005 | 11:16 PM
$tillenmax2k
Ahahaha, you feel all special for having a lower tie brace huh? I'm sure you're aware it's totally unrelated to the operation of the anti-sway bar, so i'll save the flaming.
Old May 11, 2005 | 05:26 PM
irish44j's Avatar
retired moderator
didn't say I 'feel special," I was just suggesting it as an alternative, smart guy.
I'm well aware of how the front suspension works. But if you had ever used a LTB, you would realize that it has much the same effect of a stiffer sway bar in terms of flattening out the front end (reducing body lean) and tightening up the front of the car. Obviously, it is not exactly the same in terms of the mechanical and torsional effect on the suspension as a whole, but if the thread author's goal is to flatten out the front end/reduce lean, then a LTB would have the desired effect
but you're so smart, I guess you already knew that.
...and I'll save you the flaming that you have some "tuner" work on your car instead of doing it yourself.
homeyclaus
Sep 3, 2015 06:15 PM
ef9
Aug 27, 2015 07:21 AM
Dasmith
Aug 25, 2015 10:15 PM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
