Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
first timer
Old Jul 26, 2008 | 10:07 AM
knight_yyz's Avatar
Toolie
first timer
Going to my first autox event and need a few tips as to tire pressures. I'm running illuminas, going to set at 4f 5r. I noticed a lot of guys have very high tire pressures, just wondering how that works? I thought the car would slide too much if the tires are hard. I also have rsb, fstb, toyo t1r's 225 on stock rims. 255ish fwhp.
Old Jul 26, 2008 | 04:56 PM
G4nismo's Avatar
increase the tire pressure to reduce tire rollovers. usually set the rears higher than the front say i dunno, 40 psi front, 42+ in the rear.
can always chalk your tires to see how much, if you are rolling over
Old Jul 26, 2008 | 06:37 PM
MorpheusZero's Avatar
255 section tires on stock 17x7s? You're doomed.
Old Jul 26, 2008 | 08:12 PM
G4nismo's Avatar
^^^^ yeh just noticed that. how are you running 255's on your stockers????
expect massive rollovers and a slushy ride lol
Old Jul 26, 2008 | 09:32 PM
knight_yyz's Avatar
Toolie
oops, that's a major typo. stock size 225/50/17's. I don't think a 255 would fit on a 7" wide rim. Edited the original post. Must have been thinking too far ahead and put whp number in the tire size. LOL.
Old Jul 27, 2008 | 06:24 AM
G4nismo's Avatar
thats a lot better. yeh, you should be fine
Old Aug 12, 2008 | 02:06 PM
Chio's Avatar
think about pads also and brake fluid!
Old Aug 12, 2008 | 03:13 PM
knight_yyz's Avatar
Toolie
hps pads, and valvoline synthetic, ss lines.... switching to ebc rotors and redstuff pads,
Old Aug 17, 2008 | 06:16 AM
BEJAY1's Avatar
Conecarver
Always start with higher front pressures say 40-50lbs, chalk em for rollover and drop pressures say 4lbs each run til you start chewing into the outer sidewall markers. Then go back up a bit if needed. Novice drivers tends to push tires a tad harder then vets.
Old Aug 24, 2008 | 10:02 PM
knight_yyz's Avatar
Toolie
Well, I didn't make it out a few weeks ago because my tranny synchros were toast. So I got my new 06mt installed with flywheel and stage 1 clutch and went out today. Raced with the local honda acura club. My best time was 63.1 seconds, the fastest in the class they put me in was in the 58-59 range. So I am pretty happy with that considering I am NA with street tires, and most of the cars in my class had turbos and r compound tires and half the weight.
here's a vid of my 62 second run
http://www.youtube.com/watch?v=G8rC6cLfMo8
speedy3gen
Jul 8, 2002 06:41 PM
Screaminfast
Jul 3, 2001 05:25 AM
fornimage
Feb 10, 2001 12:28 PM
