Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
Beam bending party for 4th/5th gens in the works with B14 guys.....
Old Aug 24, 2009 | 06:12 PM
95maxrider's Avatar
Lightly modded
The Sentra guys on SR20 are trying to get enough people together to get a group deal on this, as there are only a few people in the country who have the knowledge and tools to pull this off properly. Here's a link to the thread:
http://www.sr20forum.com/chassis-sus...ing-0-toe.html
The price should be around $300-$400, and may sound steep, but it's a great mod for our cars. If you have any interest, post in here and I will relay the info to the Sentra board. The location is yet to be determined, but there's a good chance it will be somewhere on the east coast.
Old Aug 24, 2009 | 06:44 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
Interesting. I would actually like to get another beam bent with 1/8" ~ 1/4" total toe out for auto-x and tighter road courses. I might be down for this.
FYI Steve's jig can't bend 5th gen beams. It only works on 4th gens and B14s. Unless he finally got around to making a 5th gen jig.
Also remove the RSB before you get it done. The beam can't be bent with an RSB attached.
I've done pretty much every suspension/chassis mod (cut Koni Yellows, Eibachs, SFCs, LTB, RSB, bushings etc) and I'm looking to get that last little bit out of my car for auto-x.
Theres always more to do for suspension/handling.
Old Aug 26, 2009 | 06:23 PM
a33i30's Avatar
sorry for the newb question... but how does beam bending help handling?
Old Aug 26, 2009 | 06:44 PM
By changing the amount of toe the rear tires have. If you were to look down at the rear tires they look like this / \ which is called toe in. This causes the rear tires to grip alot more than the front tires during cornering causing understeer. Bending the beam can make the tires look like this | | which is 0 toe or this \ / which is toe out.
I had the beam bent to 0 toe and it makes a nice difference in handling. Reduces the understeer and the car feels more balanced.
If you are into Auto-x or drive very tight road courses you can bend the beam to toe out, this causes the rear tires to have reduced grip on cornering and with other suspension/chassis changes can cause oversteer even on a FWD car. Definitly not something for a newbie driver...
Old Aug 26, 2009 | 07:21 PM
a33i30's Avatar
Oh i see, thanks for explaining, looks like i should add this to the other suspension mods i gotta do.
Old Aug 27, 2009 | 08:25 PM
BEJAY1's Avatar
Conecarver
Here's a good writeup on the bending.
http://nittotire.com/blog_detail.asp?id=33
I've been wanting this mod for 4yrs now. Steve couldn't make the '07 SER convention here in Chitown. No way I can make D.C. but the SR20 guys are suggesting KY or IN which is close. 2010 SER might be held in Milwaukee too. For the price of the bend + gas I might just have a local frame shop take a whack at it. That's why I grabbed a spare axle this summer.
Old Aug 28, 2009 | 12:17 AM
I'm surprised with all the auto-x you do that your Max's beam hasn't gotten bent yet. IIRC Steve was mentioning a B14 owner with a near stock car that had 1/4" toe out bent into his beam and went on to win his class at alot of auto-x events. It seems like a subtle change but makes a big difference in handling.
Old Aug 28, 2009 | 07:57 PM
Matt93SE's Avatar
STFU n00b!
I'm sure this is something a frame shop can tackle fairly quickly.
Then again, you only need an I-beam, some chains, a bottle jack, and a tape measure. get to it!
jerrod99_se-l
Aug 27, 2015 08:27 PM
delerium75
Aug 19, 2015 11:08 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
Samedi
Aug 12, 2015 01:54 AM
kenc15
Aug 5, 2015 08:29 AM
