Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
what the heck?
Old Jun 15, 2002 | 09:49 AM
Chebosto's Avatar
RIceD OuT moDErAtor
what the heck?
this forum should kick ***.
yay!
so. anyone have suggestions on strut settings for Auto-X?
when i was going
i had med/hard fronts
and hard rear. that made me skip alot
so my suggestion is
med/hard front
med rear
go with a high front tire psi...45
rear psi at 35
Old Jun 15, 2002 | 10:17 AM
Nealoc187's Avatar
SLOW
To make your car rotate well and not just understeer, stiffen your rear as well as raise the pressure in the rear. In the front, you want to lower the tire pressure just to the point that the tire starts to roll over onto the sidewall instead of slide. Thats why you see AutoX guys using chalk on their tires, so they can tell exactly at what pressure their front tires start to roll over rather than lose grip and slide.
Old Jun 15, 2002 | 01:16 PM
Danielsan's Avatar
Excellent information, I've never seen it on an auto x car but definitely on a drag car.
Does anyone know some good auto x sites other than scca.org? We have a local chapter at one of our colleges but the info on the site is not that great.
Old Jun 15, 2002 | 01:22 PM
Danielsan's Avatar
Ooops nevermind, just read the first post
Old Jun 17, 2002 | 08:43 PM
ryz's Avatar
ryz
I run 40 frt/ 40 bk, koni's set to med hard (one turn from the stiffest setting )
all that is great but tire type will also determine how you set up
Old Aug 25, 2002 | 04:24 PM
nismo2020's Avatar
Needs non-Maxima Friends
so i want the front tires to "plow" or roll over?
Old Aug 25, 2002 | 05:11 PM
BEJAY1's Avatar
Conecarver
Re: what the heck?
Running events kick ***. Posting on the forum takes a far 2nd place.
Old Sep 2, 2002 | 03:27 AM
mingo's Avatar
i ran 50fronts 48 rears. this was on 235/40zr18 s02
i've found that alot of the cars that do well have really have go cart like suspension, real real stiff
cheston: where are there autoX events around ucla?
Old Sep 11, 2002 | 10:55 AM
Chebosto's Avatar
RIceD OuT moDErAtor
Hollywood Park and El Toro Marine Base.
solo2.com
Old Sep 15, 2002 | 12:38 PM
Vinipux's Avatar
Re: what the heck?
chesbo, one the thing w/ tire pressure is that it's alway different, one thing you can do is use chock, I don't bother, I wash the car before the day of the auto-x so the tires have nothing on them, and then I see how far the rubber is going, and then correct the pressure by psi, it's really just fine tunning it on the spot
Konstantin
Old Sep 15, 2002 | 01:48 PM
iwannabmw's Avatar
Re: Re: what the heck?
Originally posted by Vinipux
I wash the car before the day of the auto-x.
Old Sep 15, 2002 | 01:55 PM
Vinipux's Avatar
Re: Re: Re: what the heck?
Originally posted by iwannabmw
I meant, the day before autoX
Old Sep 15, 2002 | 02:45 PM
iwannabmw's Avatar
Re: Re: Re: Re: what the heck?
Uh Huh
Old Sep 15, 2002 | 06:17 PM
BEJAY1's Avatar
Conecarver
Konstantin
Without chalk or shoepolish how do you tell which run the wear came from?
Old Sep 15, 2002 | 06:53 PM
Vinipux's Avatar
just by looking at the patern of wear everyrun you can figure out if you're running too much or too little, if you run too much you can always wear a glove and just put "swipe the marks off", they will obviously be there, but deformed from your swiping, so next time you will see where the where is, but then again, using chalk is okay too, I always forget, and don't use shoepolish unless you want it to be perminent, it doesn't come off
The Wizard
24
Oct 1, 2015 08:47 PM
sliptap
Sep 30, 2015 05:57 AM
05RLS2
Sep 27, 2015 09:24 PM
kling's maxima
Sep 3, 2015 04:45 AM
Stelianos
Aug 19, 2015 02:07 PM
