Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Touch-Up Paint
Old Jun 17, 2003 | 08:52 PM
T-One's Avatar
Touch-Up Paint
What is the best way to apply touch-up paint? The brush that's attached to the cap seem a bit too large for small nicks. Any suggestions? Also, icelandic pearl applies dark. Does anyone know if it lightens up?
Old Jun 18, 2003 | 04:48 PM
wally9mm's Avatar
I touched up many chips on my Super Black hood. They ranged from all sizes. I agree that the brush may be too large for the smaller ones. You can try applying a small amount of touchup paint with a wooden toothpick or match stick. You sort of build it up till its even. However, the finish is never the same and although you really have to look, you'll see the small impefections, especially afetr you wax.
I don't think it will lighten up, maybe after it dries and you polish? Paint matching is pretty dificult to replicate from factory applied paint.
Old Jun 19, 2003 | 07:57 AM
T-One's Avatar
Touch-Up Brush
Thanks for the toothpick tip. With the supplied brush, I get more paint outside the chip. I was also thinking of visiting an art store and looking for a super thin brush tip.
I'll try this weekend.
Thanks,
Old Jun 25, 2003 | 09:14 AM
MilwMax5spd's Avatar
when I paint little chips, I just use a fine artist's brush. I put just enough paint on the tip so that when the paint drop contacts the chip, it will just flow into the chip, filling in the hole. If you try to brush it on, sometimes the paint will dry with a ridged look.
Old Jun 25, 2003 | 07:28 PM
Pinnacle's Avatar
i have chips with burs - what should i use to get down the burs first, so its not exposed to peeling later? a fine grit wetsand or rubbing compound?
thanks,
jonathan
Old Jul 3, 2003 | 08:56 AM
shortyb's Avatar
Blobs and uneven results with touch-up paint? Try this:
www.langka.com
Old Jul 22, 2003 | 09:31 PM
T-One's Avatar
Link
www.langka.com
Thanks for the link. Have you used this product. I just received some OEM touch-up paint. I provided the parts counter with my VIN. The only problem is that my Icelandic Pearl touch-up looks silver when applied. The bottle color is Icelandic Pearl.
Old Jul 23, 2003 | 07:02 AM
shortyb's Avatar
Yep, used it about a dozen seperate times and it always comes out great. Used it on my neighbor's Cloud White Xterra and it looks perfect. Pearl colors are very hard to match. If you get a bad match with the OEM stuff, consider having a reputable body shop "scan" you car and give you a small bottle for touch-up.
Old Jul 23, 2003 | 08:22 AM
CanadianMoFo's Avatar
The Nissan stealership has paint pens available. They are like a fine point marker on each end. One end has paint the other end has clear coat. Try getting one of those. I agree the usual touch up paint brushes are just way too big for normal rock chips. Alternately go to an art supply store and get a 0/1 size paint brush. Nice and tiny to put the right amount of paint in the chips.
CM.
Old Jul 23, 2003 | 08:23 AM
ohannon7's Avatar
I just got a botlle of sterling mist touch-up paint yestersday. Im gonna try it tonight and see if it will come out ok on JB Weld.
Yes, thats right. i have JB Weld on my trunk. It may sound ghetto but i had to fill in a large hole/gap. Tonight i just gotta sand it down flush and apply the touch-up paint.
Old Jul 23, 2003 | 08:32 AM
ohannon7's Avatar
oh yea..... does the touch up paint have some sort of clear coat mixture in it or is it just paint. If so, then am i supposed to put a clearcoat over it and if so, um exactly how do i do that?
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
doctorpullit
Apr 23, 2017 05:35 AM
Luigi623
Sep 21, 2015 01:42 PM
