Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Moisture in Speedometer area.
Old Jun 19, 2003 | 11:29 PM
image's Avatar
Letme put this in E* Z* terms... I have some kind of moisture from the Host Tx weather inside my plastic area above my steering wheel.... Anyway to open this puppy up and clean it off? Also has anyone ever had this problem before?
Old Jun 20, 2003 | 12:03 AM
max_pusher's Avatar
i have the same problem with my 91 max. The plastic area appears to have some mildew or some stain growing. When I took the plastic off to get it cleaned the stain would not come off. I sprayed some WD-40 on it and let the oil soak in. Then, I wiped off the oil and it returned back to the way it was. I, too, do not know how to get the stain off. Might as well buy a new one.
Old Jun 20, 2003 | 05:07 AM
image's Avatar
where do u buy it at?
Old Jun 21, 2003 | 12:03 PM
max_pusher's Avatar
i am not sure if the nissan dealers sell this part, but I am sure if you go to the junk yard, you can find one there.
Old Jun 22, 2003 | 09:13 PM
image's Avatar
Is there any instruction to get access to the plastic? like taking your dash apart..?
Old Jun 23, 2003 | 03:31 PM
max_pusher's Avatar
yeah, you can take apart the plastic like I did but mine would not come off
Old Jun 24, 2003 | 12:34 AM
nadir_s's Avatar
vicodin ... gift of life
use rubbing alcohol to remove the stain
Old Jul 4, 2003 | 10:05 PM
Dave Holmes's Avatar
Bringing up something of an old post, but thought I'd throw this out there.
Nissan recommends against using rubbing alcohol to clean their plastics as it will fog up clear plastic such as gauge cluster, clock, etc.. There's a TSB on this.
I would use an actual plastic polish to remove a stain from clear plastic. I've done my gauge cluster and clock lens (previous owner must've used rubbing alcohol because it was foggy looking). Worked great, and even got hairline scratches out. They look like new. Best plastic polish/cleaner I've ever used is "Novus Plastic Polish #2" (and I've used a lot of them). They also have a #3 for deeper scratches, and a #1 which is a cleaner. No 2 will remove fine scratches, haziness, abrasions, and discoloration. You can call 1-800-548-6872 for the nearest distributor. If you use #3, you'll need to go over it with #2 (just like using a heavy cut polish on your paint).
To remove the clear plastic, remove the dash cluster, and then push in the tabs holding the clear plastic to it. You'll see what I mean. Be very careful or you'll break the little tabs.
Dave
Old Jul 5, 2003 | 02:18 PM
image's Avatar
where can i buy it at?
Old Jul 5, 2003 | 02:55 PM
PrinzII's Avatar
OG and counting...
You can get some plastic polishes at Auto Parts stores. However, the higher end stuff like Plexus, Autoglym, and Renovo can only be ordered online or gotten at a specialty shop.
For online links to get the polishes, check the thread called Online Detailing Supply Vendors.
Old Jul 6, 2003 | 01:53 PM
max_pusher's Avatar
I didnt know there was such things as plastic polishes. Thanks for the advice guys.
MR2 T'd
Jul 9, 2021 05:06 AM
Noela
Sep 26, 2015 08:22 AM
jchronis2552
Sep 21, 2015 05:52 AM
Djsmaxima
Sep 14, 2015 11:58 PM
