Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
how to remove hard water spots on hood
Old Sep 9, 2003 | 05:57 PM
AscendantMax's Avatar
i got 4 lines of hard water marks on my hood, where the water would squirt out out of those windshield washer things. i try to use filtered water when refilling the resevoir but i guess some calcium remains. i've tried using car soap when cleaning it and even scratching it with my nails, still no use. is my only option claybar-ing it? thanks in advance.
~FF
Old Sep 9, 2003 | 06:10 PM
maximumspeed's Avatar
You could also try a 50/50 solution of distilled water and white vingar in a spray bottle,it works pretty good at removing waterspots and your wax so be sure to wax the part you sparyed when your done.
97 MAXIMA SE
Old Sep 9, 2003 | 07:58 PM
Dave Holmes's Avatar
I second what Maximumspeed said. A claybar can help, but if they're baked on, you may need to go to a paint cleaner/polish. Remember to always start with the least aggressive product, and work up from there. The step 1 cleaners from Meguiars or Mothers 3 step systems would probably take care of it. If not, try a swirl mark remover (like Megs #9). If those don't do it, then something like Megs DACP (Dual Action Cleaner Polish), which is more aggressive than #9. I seriously doubt you'd need to compound, so I'd stay away from those. And keep in mind that most glazes won't remove blemishes, but rather hide them. Read the bottle, because some manufacturers interchange the terms "glaze" and "polish".
After they are removed, apply a good wax. Several light coats would be best to prevent them from coming back (if you use a one step/cleaner wax, they usually won't layer because the cleaners remove the previous layer of wax).
I use RainX washer fluid (rejuvenates my RainX application supposedly), and haven't had spots appear that wouldn't wash off. Or if you're hell bent on using water, try store bought distilled or something.
Dave
Old Sep 9, 2003 | 08:33 PM
hmm, thanks for the replies guys. i was hesitant to buy that rainx washer fluid because i don't know how well they work or if it'll hurt the paint. i'll give that stuff a try.
Old Sep 9, 2003 | 11:58 PM
nadir_s's Avatar
vicodin ... gift of life
try the claybar, it should remove it.
Old Sep 18, 2003 | 12:01 PM
maxNYC's Avatar
clay removes contaminents. try it out.
trailer54
Nitrous
Nov 18, 2015 07:44 PM
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
