Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Using clay...
Old Oct 1, 2003 | 08:32 AM
Doc's Avatar
Doc
Using clay...
First of all, having never used the stuff, can one of you folks be so patient as to give me a quick version of how you use it? As I understand it, it is used basically to pick up the hard to get off stuff from the paint. A guy I know in the detailing business told me they always use Play-Doh. He said it works as well as clay, which can be expensive, and you can save it from drying because it comes in a sealable container. What are some thoughts?
Old Oct 1, 2003 | 08:45 AM
PrinzII's Avatar
OG and counting...
a) This is how I do it:
If I am using the supplied lube (car is dried)
- Spray lube on surface to be clayed, not to exceed 2'x2'
- Break off portion of clay bar and mold it into a patty
- Take portion you broke off and rub it on the lubed surface in a linear motion until the clay starts to literally slide on the surface. No downward force is necessary as the clay will do all the work for you.
- Wipe the area with a microfiber towel
- Follow up with a polish and/or wax
The quick method
- After rinsing the car off, start claying immediately after the final rinse.
- Dry the clayed area using a microfiber towel
Bear in mind, you will need to do this a quarter of the car at a time.
b) Your best bet as far as clays are concerned would be:
Clay Magic
Mothers
Pinnacle
Zaino
Old Oct 1, 2003 | 08:58 AM
Doc's Avatar
Doc
Thanks for the input. Much appreciated.
Old Oct 1, 2003 | 10:17 AM
2k1seae's Avatar
I used the lubricating stuff (Meguiar's Quik Detailer) with their clay bar once and didn't care for it. It was a lot of work and didn't work any better than just plain water IMO. After I wash and rinse the car, I use the clay bar (Clay Magic; cut into 3 pieces and formed 1 piece into a patty) with plenty of water. Do a small section and rinse. As the bar gets dirty, just fold over so dirt is on the inside. Do this whenever the bar gets dirty. I will use the bar 2 - 3 times and I store it wrapped in wax paper in a Tupper Ware (air tight) container. This works great for me and I don't have to buy the lubricator. Good luck.
Old Oct 1, 2003 | 07:53 PM
guapsnaman's Avatar
Yea..use A LOT of the lube.
Old Oct 8, 2003 | 05:42 PM
white95max's Avatar
AAAAAHH! MY EYES!
Use a friendlier color next time! geez!
Old Oct 9, 2003 | 06:58 AM
bigcozz's Avatar
Alot of lube is a great way to go...I also think that the detailing spray that they give you is the best thing to use because water is not a good lubricant...Every try it in the shower and you will know what i mean.
Old Oct 9, 2003 | 08:12 AM
2k1seae's Avatar
Been claying for a several years on black cars and never had a problem. Key is to keep the car wet and rinse after small sections of the car. But hey ... I know what works for me. Whatever works for you is great.
Old Oct 9, 2003 | 09:23 AM
The Gange's Avatar
Play-doh? Anyone?
xydavid
Dec 22, 2002 12:10 PM
