Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Cleaning headlight Covers '03 Max
Old Nov 14, 2003 | 07:43 PM
speediq
Hello,
The headlight plastic covers in my '03 max have discolored a bit and are becoming opaque and cloudy. Glass cleaner doesn't do the trick. Someone suggested 1500-2000 sandpaper but I am not sure of the results.
Is there anything I can use to restore the covers?
I tried finding just the plastic covers but it looks like you have to purchase the entire assembly. Does anyone know of a place that sells just the cover?
Thanks,
Mike
Old Nov 14, 2003 | 07:46 PM
maximadave's Avatar
detailerdaveb@gmail.com
just buy some plastic polish. I use this stuff called Blue Magic plastic polish that I bought from Pep Boys for about $5. Works great.
Old Nov 14, 2003 | 11:25 PM
Dave Holmes's Avatar
A good plastic polish will work. I personally use Novus #2 plastic polish. I've used many others for lenses and instrument panel lens, but none have performed like Novus. Novus has the #1 cleaner, #2 polish for medium scratches/haze, and #3 for heavy scratches. #3 is very aggressive, and creates its own haze that needs removed by #2. But, it will remove scratches you wouldn't think possible. #2 is probably what you need for the yellowing you described.
A relatively unknown trick I learned one day on autopia.org, is to use Mother's Mag & Aluminum polish. I use it on my headlights ('97 if it makes any difference) as an "everyday" polish (to clean, not remove scratches), and after polishing out scratches with Novus #2. It works AMAZINGLY well. It, too, will remove yellowing from them. It leaves them with a sparkle that other polishes lack. I believe the sparkle is from the protection it leaves behind. Oh, did I forget to say that it leaves a protective layer to help prevent yellowing/hazing? Just use it as any other polish (and the directions are on the tub), and you'll be amazed at the yellow that comes off.
If you can't tell by the length of my post on polishing headlights, I am very picky about my plastic. These are the products (Novus-especially #2, and Mother's Mag & Aluminum Polish) that I use exclusively now for plastic.
Post back with your amazement if you try the Mother's Mag & Aluminum Polish.
Dave
Old Nov 15, 2003 | 07:51 AM
pruizgarcia's Avatar
I use the Mothers Mag and Polish on my wheels, so I decided to give it a try on my lights. I am impressed. Miner scratches are gone and the plastic is clear with no yellow. It looks nice. Thanks for the tip.
Pedro
Old Nov 15, 2003 | 02:29 PM
PrinzII's Avatar
OG and counting...
However, the '02-'03s were known for a headlight "haze" that actually came from inside the housing.
But I treated the outside of my '02's plastic housing with Plexus and there was a difference.
However, I will pick up some Mother's Polish since I like using that for metal anyway.
Old Dec 8, 2003 | 06:59 PM
Adrian's Avatar
plexus i use every time i wash my car on all exterior light houings still clear and shiny
Old Dec 9, 2003 | 07:24 AM
endus's Avatar
An atavistic endeavor...
Novus #2 will polish the discoloration and some of the light pitting out. Plexus is good to follow up with when you clean the car.
Old Dec 13, 2003 | 12:51 AM
KNOCKTURNAL's Avatar
the blue magic polish works great. haze is now gone but now i can see some stains on the inside of the light. anyone else have this problem?
Old Dec 13, 2003 | 07:07 AM
clipse's Avatar
Where do they sell the "Novus" or "Plexus" product at???...
Old Dec 13, 2003 | 12:10 PM
Adrian's Avatar
plexus at properautocare.com
Old Dec 13, 2003 | 03:27 PM
MaxSE03's Avatar
http://store.yahoo.com/classic-motor...slenclean.html
wellz
Aug 26, 2015 09:05 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
Nintensity
Aug 13, 2015 05:41 PM
jholley
Aug 11, 2015 09:38 AM
