Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Orange peel?
Old Nov 18, 2004 | 06:01 PM
TsingTsaoNYC's Avatar
Orange peel?
What is orange peel (sorry, kinda of new to detailing)??
Old Nov 18, 2004 | 06:11 PM
BlueC's Avatar
wat
Orange peel is that texture you see on an orange on the paint. Look at an orange, look at the texture on the outside, thats what the paint would look like. Its from spraying paint too dry.
Old Nov 22, 2004 | 09:26 AM
gto400no1's Avatar
it also can be cause by a cheap spray gun, poor prep work, or an unexperienced painter.
-Tom
Old Nov 22, 2004 | 10:19 AM
white95max's Avatar
If you look at a car with orange peel (almost any car) the reflections appear wavy and unsharp. This is because the clearcoat is not perfectly smooth, which distorts the reflections.
Old Nov 22, 2004 | 09:22 PM
wylie-c's Avatar
There are many things that can cause orange peel,
Not quite enough product applied,
Air pressure too low,
Not enough reducer, wrong reducer or mix ratio incorrect,
Incorrect gun setup,
Baked too soon / or accelerated too much,
Too much product applied,
Basically listed in order of likelihood. Even a $50 gun can lay down a glassy coat of paint when it's used by an experienced painter. I have cheapo $75 gravity feed's for general use, and $500 DeVilbiss's for the important jobs. I have repainted brand new $180,000 Peterbilts with the cheapie gun, and it looked better than factory.
What it comes down too, is orange peel, when excessive, is simply a crappy paint job. Every paint job has some degree of it, it's the nature of sprayed paint, but if it looks like cottage cheese, whoever painted it probably doesn't know what they're doing.
Old Nov 22, 2004 | 10:45 PM
S00NR1's Avatar
OU > *
Old Nov 23, 2004 | 04:46 AM
fstbusa's Avatar
you can see the roughness around the reflected light. Thats orange peel
Old Nov 27, 2004 | 08:00 AM
Wil's95SE's Avatar
我爱台湾
What can be done to take care of it? Is there anything you can do that not's too drastic or doesn't cost as much as a new paint job?
Old Nov 27, 2004 | 07:54 PM
white95max's Avatar
There isn't much you can do short of a new paint job. Even the new paint job would probably have orange peel.
Old Nov 27, 2004 | 09:18 PM
Broaner's Avatar
2060lbs and falling...
Wet sand no?
Old Nov 27, 2004 | 10:22 PM
white95max's Avatar
I suppose wetsanding could repair orange peel somewhat, depending on how serious the orange peel is.
Old Nov 27, 2004 | 10:33 PM
BlueC's Avatar
wat
Wetsanding is exactly how you fix orange peel. Usually, if you want a top quality paint job, you'd want the paint color sanded. Basically before clear coat, the actual paint would be wetsanded down to be flat to eliminate any imperfection. But doing this requires more paint to be layed down since you'd be sanding some away. Same goes when you lay down the clear, you'd want to wetsand, but with a higher grit. Then follow up with a compound and polish and that thing would be shining.
NERDJUSTBNME
Sep 30, 2015 03:20 PM
sliptap
Sep 30, 2015 05:57 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
