Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
touch up paint job gone terribly wrong..what do i do now?!
Old Mar 28, 2005 | 05:37 PM
roll4life's Avatar
so i had a buncha line scratches that are pretty deep on the side of my car and i decided to fix them myself..i sanded it down a little bit and then used alcohol to clean it and then i taped over everywhere to surround the scratches...then i used touch up paint like 5 coats and then 1 coat of clear coat and now it looks nothing like the original black paint..but rather like greyish thing lines?!?!how do i make them match? please help guys
some pics of the terrible stand out paint fixes
Old Mar 28, 2005 | 05:59 PM
99se5spd's Avatar
it looks like horrible orange peel, did you use factory touch up? spray or brush? you maybe shoulve wet sanded 1500 grit or finer before you applied the clear and your defenatelly not going to be able to blend it in very well. i would get ahold of some langka ( langka.com) and hopefully that will take it all off and you can start over again just filling in the scratches not the surrounding area, if and when you remove the touch up you applied you will probably need some good rubbing compound and probably 2 grades of polish to get it looking like it did before you started. someone elswe will have to chime in here with more experience.
Old Mar 28, 2005 | 06:00 PM
BlueC's Avatar
wat
Looks like you applied the clear coat wrong. Typically its not a good idea to use clear coat in big areas like that, cause its very difficult to blend it. Touch-up paint sands much easier so its easy to blend it into the current layer of paint. Do some wetsanding and try buffing that out with some Rubbing compound, followed by some Machine glaze. Start there.
EDIT: From what I see in the pictures, it looks like you masked off that area, and sprayed on the base coat and clear coat. Wasn't a good Idea obviously, its not gonna be easy to sand that down evenly since it will have some tall ridges on the edge where you masked. Wetsanding really might be you're only option. Langka wouldnt hurt to try, so i'd be the second to reccomend that.
Old Mar 28, 2005 | 06:11 PM
roll4life's Avatar
damn man..this makes me so upset...im guna go to pepboys tommorow and see if they have anything i can use to blend it in or take it off
Old Mar 28, 2005 | 06:15 PM
BlueC's Avatar
wat
Only way to blend it is with wetsanding.
To take it off, Langka might work, but im not too sure about the product.
Old Mar 28, 2005 | 06:20 PM
roll4life's Avatar
yea ill try to wetsand it and then maybe use langka if i can find it around the local auto shops..but damn why doesn't it match at all..i got the right spray touch up paint and did everything pretty clean but it looks like **** now
Old Mar 29, 2005 | 07:09 PM
roll4life's Avatar
well today i wetsanded it 1200 grit and then polished it..it matches a little better
Old Mar 29, 2005 | 07:52 PM
BlueC's Avatar
wat
You'll want to do the following. Start off with 1200, and work your way upto 1500, then finish with 2000. It will make the compounding part much easier.
Old Apr 2, 2005 | 08:09 AM
04BlackMaxx's Avatar
Wow, I thought I had a problem with a little dent lol.
Old Apr 2, 2005 | 10:12 AM
Jatan's Avatar
Updated pics?
Old Apr 2, 2005 | 10:00 PM
roll4life's Avatar
hey my car is 4 years old man..give me a break
as for updated pics..i will take some in a few days..it looks a lot better but still pretty bad..i wouldn't recommend anyone to use touch-up spray paint and clear coat enamel on large areas..it wont match
Old Apr 2, 2005 | 11:00 PM
PrinzII's Avatar
OG and counting...
You are going to have to do that and then find someone to buff it out with a rotary.
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
