Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Recommend a good or perfect cutting pad for heavy swirls and scratches
Old Sep 27, 2005 | 01:23 PM
deezo's Avatar
I have a yellow cutting pad but I don't think I'm using the right compound for the job. I see people using Meguiars Dual Action Cleaner/Polish and getting great results with it. I'm going to buy the cleaner/polish from Meguiars but what brand pad should I use to apply it?
Old Sep 27, 2005 | 01:25 PM
BlueC's Avatar
wat
Use Meguiars pads. I use 3M products, but I have a friend of mine thats using the same pad as me, but using the Meguiars DACP. It should be a maroon colored pad, the cutting pad. I love these things, none of them have diminished in quality or have had any troubles with the jobs I have performed.
Old Sep 27, 2005 | 01:36 PM
deezo's Avatar
I use 3M also but I think my cutting pad is weak (maybe I'm not working hard enough). I'll look up the pad you suggested.
Old Sep 27, 2005 | 01:40 PM
BlueC's Avatar
wat
What are you using the pads with? If its with a PC 7424, you will have NO troubles getting swirls out if you use the pad im talking about. Aslong as you are using a good compound like the DACP or a 3M Rubbing compound.
Old Sep 27, 2005 | 02:22 PM
BigLou93SE's Avatar
How does DACP or 3M rubbing compound compare with Sonus SFX-1 (restore)? I used this and SFX-2 with an Orange sonus DAS pad (and then the green one for sfx-2), and still some swirls are present.
Oh, Porter Cable 7336 btw
Old Sep 27, 2005 | 04:48 PM
soundmike's Avatar
Very sound, Mike
This chart will help you out:
http://dano.pocketrubbish.com/detail...oductchart.htm
DACP is good but to me it works just like SFX-1, they do a good job but not good enough for deep scratches or swirls. A Heavy-cut compound would probably work better. If you're up to it, try wet sanding the area and move your way down the chart as far as product application goes.
Old Sep 27, 2005 | 05:53 PM
BlueC's Avatar
wat
This is the method I choose for areas that are heavy in swirling and/or have somewhat deeper scratches and scuffs.
Old Sep 27, 2005 | 07:00 PM
PrinzII's Avatar
OG and counting...
deezo: I currently have the Sonus SFX cutting pads (including the 4" spot pads) and the Sonus DAS pads. I would also look at the Lake Country Orange or Cutting Pads as well as the Meguiar's pads.
I used the Sonus SFX Yellow Cutting Pad and DACP on this '36 Ford with the PC running at 5 to reduce the swirls.
In your case, deezo, I would recommend Menzerna PowerGloss.
Old Sep 30, 2005 | 06:07 AM
gto400no1's Avatar
3M swirl remover, best on the market. give it a shot.
Old Sep 30, 2005 | 09:38 AM
deezo's Avatar
Ok. I'm going to try the Menzerna Powergloss with my current Yellow pad and see what results I get.
Thanks for the replies guys.
Thanks for the chart SoundMike.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
rbuswell
Nov 17, 2016 04:54 AM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
