Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
cleaning behind the wheels
Old Dec 6, 2005 | 07:25 AM
jaedaliu's Avatar
I'm doing my first brake job this weekend. When I took off the wheel and caliper to inspect my breaks last weekend, there was grease and grime and gunk that got all over. The stuff was caked on everything that wasn't a contact surface.
Is there a good and safe way to clean that stuff up? The wheel (steel with hub cap) hasn't come off since the last time the brakes were replaced. Or should I just leave it alone since nobody's going to see it after I put the wheel back on after I'm done with the brakes?
Old Dec 6, 2005 | 07:31 AM
Terran's Avatar
I don't think I'd worry about it too much since you can't see it, but a wheel cleaner (probably lots of it) should do the trick. Eagle one makes a pretty strong one as long as the one in the silver bottle is the same as the old stuff (I'm not sure whether it is or not).
Old Dec 6, 2005 | 08:20 AM
NismoMax80's Avatar
SuPeRmOd
A rag, soap and water? I just wipe off what I can and not worry too much about it. you should be more concerned about where the grease is coming from. Make sure you don't have a leaking boot.
If really stuck, I also have Eagle1 wheel cleaner. Just get the cheapest you see.
Old Dec 6, 2005 | 11:45 AM
rsly33's Avatar
If its really caked on, then its going to take alot of work. Get a strong wheel cleaner and try using #0000 steel wool on it. Only use the steel wool on the inside of the wheel though, it will scratch the wheel a little.
Which hubcaps do you have? If they are the full ones that cover the entire wheel, I wouldnt even bother cleaning the back, no one will see it anyways
Old Dec 6, 2005 | 05:30 PM
jaedaliu's Avatar
sounds like a plan!
I'll check my cv boots and ignore the grime if the boots are intact.
Old Dec 7, 2005 | 05:53 PM
SiriusRIMZ's Avatar
Try using a power washer with some degreaser like simple Green, cuts break dust and grime nicely.
Old Dec 7, 2005 | 07:08 PM
86maxima96's Avatar
I Broke OT
i heard brake cleaner works well
Old Dec 8, 2005 | 10:25 AM
Terran's Avatar
Yeah, I've seen mechanics do that. It would probably be fine if you wash it off right away. Don't blame us if it takes the paint off too though.
Old Dec 8, 2005 | 11:03 AM
rsly33's Avatar
Brake cleaner is fine on paint
Brake fluid is what strips paint
Old Dec 8, 2005 | 11:52 AM
86maxima96's Avatar
I Broke OT
either way, don't let any strong cleaner sit on it if you know what's best. just srub a spot for a while and then rinse it off. the scrub again.
matts95max
Apr 23, 2025 10:44 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
