Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Removing Chewing Gum From Carpet
Old Apr 19, 2006 | 06:30 AM
DTinVA's Avatar
I need some advice about removing gum from my trunk mat. It was on the bottom of something I put in the trunk the other day and didn't realize it was there till today. It is still a little gummy - not solid (if that makes any sense).
Thanks in advance!
Old Apr 19, 2006 | 08:33 AM
nadir_s's Avatar
vicodin ... gift of life
u can try ice on it and rubbing it off (it ***** up and come's off) ... since the trunk carpet is so shallow, it should work out.
Old Apr 19, 2006 | 09:06 PM
The Gange's Avatar
When I worked as a janior at our Junior High, we had cans of something that would freeze the gum very quickly, we then just took a putty knife to it and it came right up. Maybe a can of compressed air turned upside down will take care of it.
Old Apr 21, 2006 | 07:37 AM
jbelosic's Avatar
WD-40 will remove the gum, but then you need to use a citrus degreaser to remove the WD-40. I would test this method on a spot that doens't show to determine if it'll leave a stain.
Old Apr 22, 2006 | 01:17 PM
KeithD's Avatar
Dry ice freezes gum and makes it real easy to remove...however a combination of ice, a good carpet cleaner, and some elbow grease will probably work best..
Old Apr 24, 2006 | 12:03 PM
bvenvert's Avatar
Goo Gone
I have had to remove gum from a number of carpets and the best product I have found is called "Goo Gone". They sell it everywhere, including Walmart and Kmart, for about $3.00 a bottle. It is designed to remove tar, paint and gum from porous surfaces and it has an orange/citrus smell.
Basically, pick away any excess gum you can before use. Dab a little goo gone on a soft cloth and start working on the gum stain from all sides into the center. It will gradually start to "ball up" the material until the gum is basically gone. It works pretty well and doesn't leave a stain on the carpet.
Old Apr 29, 2006 | 05:30 AM
AresFury's Avatar
Yeah goo gone is really great stuff for those nasty spots.
Old May 13, 2006 | 05:00 PM
RKZ's Avatar
RKZ
Get the stuff the spray keyboards with the dust them and turn it up side down and spray the gum to freeze it.
Old May 14, 2006 | 09:05 AM
98MaXeDouT's Avatar
+1 That should do it.
Old May 29, 2006 | 09:03 PM
hogey228's Avatar
try peanut butter. one time i had gum in my hair, put some peanut butter, and it washed right out.
Old Jun 18, 2006 | 12:26 AM
Eyemfaster's Avatar
i guess that would work, but you would need to clean up the peanut butter from the carpet then
Old Jun 27, 2006 | 10:23 AM
mistermaximum's Avatar
Krud Kutter is a great solvent that they sell I believe at Walmart.
Old Jul 6, 2006 | 02:30 PM
Da_Shatterer's Avatar
Any form of freezing the gum first would be best. That's how I've always gotten gum outta clothes and upholstrey. Try it out
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
jaydot901
Sep 29, 2015 01:18 PM
