Okay what's my next purchase? Polish Pad
Jun 30, 2006 | 02:26 PM
So here's the deal. I'm not some all out super dupity detailer. This is what I have.
Rotary grinder/polisher. It's okay I'm experienced with it. Not a pro but not bad.
Wool buffing pad. Old and new one. I've used it to polish before but I read wool ones are too rough for fine swirl removal.
Products: Mequires and 3M stuff since it's easy to buy and I'm used to them. From rough to fine: 3M polishing compound. Rough stuff I know. Mequire's #2 and #9. Also have their cleaner wax. Just bought their clay kit.
Now I think I can use the wool pad with the #2 and the cleaner/wax. But I'd like to buy a foam pad for the #9 or anything finer to finish it off.
Any recommendations. Does any local chain suppliers have a decent foam pad for my application?
Jun 30, 2006 | 06:18 PM
Try the Lake Country white foam pad. They market it as a polishing pad and I've had very good results with it. About medium in the abrasive scale (wool would be very abrasive) The least abrasive would be the black pads.
Jul 1, 2006 | 06:59 AM
Jeff: The wool pad is actually more aggressive than many foam pads. I would recommend the ones that Blues is suggesting as well as Propel pads.
Alternatives would be the Sonus SFX series.
Jul 2, 2006 | 06:58 PM
I would probably skip the Wool pad. Makes more work than neccessary. Stick with a couple foam pads w/ the rotary. Should do the job.
Jul 5, 2006 | 07:47 AM
Well I was wondering if I could use the wool for the #2 and rougher (if needed) and just buy one foam pad for swirl removal? Thanks for the suggestions
