Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Removing chrome plating from wheels?
Old Feb 2, 2008 | 03:02 PM
zero2sixtyZ's Avatar
You embarrass me.
I have a set of wheels that are chrome plated but peeling, and I need to remove it all off in order to paint them. Any advice would be very much appreciated!
Old Feb 4, 2008 | 06:32 AM
You embarrass me.
Bump, anyone? Need assistance!
Old Feb 4, 2008 | 08:12 AM
!PrjctMax!'s Avatar
Quick guess...sand paper? You're saying that you're going to paint them, so wouldn't you have to do that regardless?
Old Feb 4, 2008 | 06:51 PM
Nissan 6's Avatar
wow too bad that would take forever.
Try going to an auto store or hardware store to look for a chemical that removes chrome. I think your best bet if you are going to paint them would be to go to a powdercoater and see if they can sandblast the wheels for you for cheap.
Old Feb 4, 2008 | 08:08 PM
!PrjctMax!'s Avatar
***** much?
I like how your only posts in detailing are quoting me
Old Feb 4, 2008 | 08:25 PM
Nissan 6's Avatar
What? I snoop in this forum from time to time I don't care whose post that was, it was a retarded suggestion.
Old Feb 5, 2008 | 08:28 AM
!PrjctMax!'s Avatar
oh ok, you are teh pro d00d
Old Feb 6, 2008 | 05:05 PM
djfrestyl's Avatar
Suspension Yoda
Aircraft stripper will take it right off.
Old Feb 11, 2008 | 12:12 PM
You embarrass me.
I will try the aircraft stripper first, as this is what I originally pondered about. Is it something I apply/wipe or something I let the wheel soak in?
Old Feb 11, 2008 | 03:14 PM
djfrestyl's Avatar
Suspension Yoda
Spray it on, let soak, use a wire brush. Then I believe it just washes away. I've never done it myself but this is what I imagine the process would be. Make sure you're only using the stripper on metal.
Old Feb 11, 2008 | 05:09 PM
Matt93SE's Avatar
STFU n00b!
http://www.google.com/search?q=removing+chrome
Basically, the first six links say "pay a pro". it's a ***** to do and you can't do it at home properly.. not without naaaasty chemicals that will melt you and your house.
Old Feb 11, 2008 | 07:33 PM
djfrestyl's Avatar
Suspension Yoda
Thanks Matt for the clarification.
My apologies for the far off information. Somehow I thought paint ~ chrome.
Old Feb 11, 2008 | 08:34 PM
96blackmaxSE's Avatar
boost me.....
I have used aircraft stripper on my stock 96 sawblades before I did a paint job...Altough they were not chrome, it easily bubbled up the clear coat and I power washed and scraped them with a wall paper remover
Old Feb 12, 2008 | 09:07 AM
Matt93SE's Avatar
STFU n00b!
yeah... aircraft stripper will peel paint and powdercoating off. but chrome is an actual metal plating. it's not paint. it won't just dissolve when you pour paint stripper on it.
Old Feb 12, 2008 | 10:33 AM
sciff5's Avatar
I would think that if its already peeling off media blasting it would take care of it pretty quickly. Media blast them and then paint them. It would be very quick.
Old Feb 12, 2008 | 05:22 PM
Matt93SE's Avatar
STFU n00b!
I think you're forgetting how tough the actual chrome is.....
Old Aug 16, 2012 | 02:21 PM
kingrukus's Avatar
no more maxima...
What did you end up using to remove the chrome?
Old Mar 14, 2014 | 12:15 PM
jaydubb's Avatar
Resurrected...
How about Oven Cleaner???
Old Aug 2, 2014 | 05:21 PM
BIGIRISHSTL's Avatar
Unfortunately, the chrome is an actual tarnish after it meets oxygen so media blasting or nasty chemicals including dipping it to deplate it are the only way to go. Good luck
Old Aug 12, 2014 | 06:32 PM
viprider's Avatar
Air craft stripper can remover the old chrome. Unless its hard chrome which need extra work and materials like sand blasting.
matts95max
Apr 23, 2025 10:44 AM
The Frye
Feb 3, 2019 08:34 AM
BkGreen97
Apr 2, 2016 05:47 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
