Buff Scratches on Trunk Lid?
So my brother did me the favor of washing my VE with a self-serve car wash. He used the foam brush on it and it scratched the sh*t out of the trunk (surprisingly, nothing else that I noticed). It only appears to be clear coat damage like someone hit it with 100 grit sandpaper, but it is still fairly noticeable. Will a buff job clean it up all right or should I look for a new paint job?
Well I did do a wax job on it just this evening and that seemed to be some improvement. You can still see the scratches in the light at the right angle though. So if that helps any, it is deep enough to see it still, but shallow enough to sort of get by with a good wax job.
If you can feel the scratches with your fingernail, they are deep and will require some serious correction. If not you can restore your paint with a good polishing from a random orbital polisher and some care. I'd start out with a medium cutting polish first and if you don't get the required results, move to a heavy cutting polish with coarser abrasives to get them all out and finish up with a medium after that to make it really glow. Be sure to protect it with a sealant for long lasting protection or a wax for less durable protection but more shine.
The most important thing after you do this is to wash and dry it properly so as not repeat the mistake again. Or strangle your brother.
Thanks for the tips guys! It is the better looking panel on the car after having it buffed with the orbital! Problem that I ran into is that the rest of the car does not have the original paint. Once upon a time, there was a real cheap repair job done to it and so there is a lot of over-spray. Couldn't really do much in the way of buffing or the paint would come off. Figure it best to get it repainted someday when I get the money/move off campus.
I have tried clay bar on the whole body and nothing came up but the obvious grit. I have a feeling that there was some clear coat sprayed over it as well, which could be why it has lasted so long. All the clay bar, wax, and polish do is shine it up. Looks good, but does not really fix the problem.
REDinLV
Aug 15, 2024 12:30 AM
steveyphat
Sep 15, 2015 03:43 PM
rbaker100
Sep 6, 2015 02:46 PM
