Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Coffee stain on seat belt
Old Jan 24, 2013 | 04:05 AM
Torchcorvette's Avatar
I am trying to remove coffee stain on seat belt and have tried several cleaners....409, Simple Green, Tarminator, etc. to no avail.
Any suggestions are welcome. Thanks in advance.
Old Jan 24, 2013 | 04:21 PM
LazYRaCeR's Avatar
Rubbing alchohol? you can try to use a steamer and steam it out.
Old Feb 12, 2013 | 05:03 PM
95maxrider's Avatar
Lightly modded
What are you using to scrub it with? I'm thinking that having another cloth-like surface for it to transfer to might be a good idea, but then again something like a stiff toothbrush might be good if done first. I've had good luck using Purple Power when Simple Green just didn't cut it and have been impressed, so you could also try some of that. Maybe also find a way to let that section be submerged in a cleaner for a while before you scrub/dab it.
Old Feb 12, 2013 | 05:17 PM
Fakie J Farkerton's Avatar
^^this with a towel behind it blasts the nastage right through it.
Old Feb 16, 2013 | 01:14 PM
Hectic's Avatar
The problem is that your seatbelt is now DYED, not stained. The belts are so tightly woven, getting the coffee out will be virtually impossible.
That said, I have never tried the above steaming methods, so that might work. No cleaner or manual scrubbing is going to get you much of anywhere though.
Old Feb 16, 2013 | 01:24 PM
Thanks to all for the advice and suggestions. I've tried every cleaner available. No change.
I guess I'll try steaming it.
Old May 30, 2013 | 07:42 AM
kctyphoon101's Avatar
There is a cleaner that begins with a "z" I think.. it is what the professional cleaners use from. Bob's furniture if u buy their "goof proof" protection.. I've used it to get blood out and its worked. Ill post the name of it for you when I get home.
Old May 30, 2013 | 07:17 PM
Old May 30, 2013 | 07:23 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
