Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Dyno results from today - MEVI without ECU
Old Aug 9, 2003 | 06:31 PM
speedemn's Avatar
Well, just to share with you guys, here's my dyno from TAG today. I got a peak HP of 187HP and peak TQ of 180lb.ft... that's up from 177HP/174TQ from last time. This is what changed:
Definitive Motorsports pulley installed
New spark plugs installed - copper
I also set my Harlan RPM switch to 5100RPM (which is why the HP/TQ do not dip after 5000RPM as you can see in the blue dyno line from last time).
The temperature conditions were about the same... not as much of a correction factor, yet the numbers are still quite a bit higher than last time... so at least I was able to get a comparative dyno.
I kept the test pipe off... and am running my old stock cat. I wonder if I plopped that back on, if I would get another 5HP or so, that I lost from last time. Here's the dyno from last time of stock cat vs test pipe:
Old Aug 11, 2003 | 12:54 PM
I30tMikeD's Avatar
you should set you VI at 5300 or 5400.
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
gigabyte
Jan 6, 2017 06:05 PM
Sep 27, 2015 08:37 AM
