Looking for feedback on my dyno
I dynoed last Saturday and I have mixed feelings on it. The dyno is here Peak hp is lower than expected for my mods but torque seems about right. I have be unable to locate any dynos for stock 00-01 auto so I do not have a baseline to compare it to. I was curious if some of the dyno experts could take a look and tell me if there signs that indicate any problems. Only thing else changed besides the mods listed on the page were copper replacements in stock heat range gapped correctly. Any advice or insight would be greatly appreciated.
Haydn Jr.
Haydn Jr.
Seems about right if you're auto. But, your mods should have brought it up more. BTW, where did you get your timing advance at? And on your plot link, you said all runs were run in 3 gear, up to 65 mph? w O/D off? I didnt follow that. But it does seem alittle low. Maybe i's just the dyno.
a stock 00-01 automagic dynos at about 165 fwhp with a low of 160 and a high of 170. Yeah you should had a bit higher peak numbers.
Check general maintenanc issues, and also tire pressure/alignment, y-pipe flex section, etc.
Originally Posted by JMAXIMA
how would the flex section affect dyno #'s that much? i know i have a loose flex section in my budget ypipe, could that be a reason of my low numbers?
yes if you mean the flex section is collapsing...
dunno if it is collapsing or not... haven't had enough time to look inside.... from the outside it looks ok.... but it rattles like a ****** phucker.
MannyMonroe
Sep 25, 2015 12:38 PM
soybeanz
Sep 25, 2015 10:46 AM
