Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Dyno'd 2001 Auto AE
Old Dec 17, 2005 | 01:37 PM
A33 VQ30DEK's Avatar
Dyno'd 2001 Auto AE
Finally got to dyno mycar today.
173 bhp
199 torque
Stillen Y-pipe, Muffler, Berk Intake.
VI is working great. Opens up at 5200 rpm and you see the torque and power just climb from there!
I'll post the dyno sheet later on.
Old Dec 17, 2005 | 01:59 PM
Kevlo911's Avatar
Kevlo for President
Numbers seem kinda low. I thought 00-01 auto's made 180hp stock.
Old Dec 17, 2005 | 04:36 PM
konak85's Avatar
Torque is good but hp seems kinda low
Old Dec 17, 2005 | 09:16 PM
NmexMAX's Avatar
dot dot dot ...
: Graph .. run files
Old Dec 18, 2005 | 01:33 AM
http://forums.maxima.org/showthread.php?t=439706
well if you look at that link above, that guys 2000 auto maxima only dyno'd 185 to the wheels with more mods then me, but less torque. I'm not to worried after i do my 5 spd conversion!
Old Dec 18, 2005 | 05:28 PM
NmexMAX's Avatar
dot dot dot ...
Do you have a graph or run file?
Old Dec 18, 2005 | 05:34 PM
upstatemax's Avatar
He did not even have a y-pipe at the time, and that is not with the N2O...
Your hp numbers are low, any maint. you have missed??
I need to get mine on a dyno, I am just saving it for when I get an VAFC...
Old Dec 18, 2005 | 07:07 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i have never seen an 00-01 auto dyno 180 stock. the best i have seen was around 186 and that with the more important bolt ons. with that said, the hp seems low but torque seems high. what gear were the pulls done and what machine was it run on?
Old Dec 19, 2005 | 02:18 AM
well i'll take a picture of the graph tomorrow, but i showed it to my brother and he said that the graph had a spike on it. Something went wrong. So i think the 199 torque is wrong. But if you think about 25% power loss due to an automatic comes out to about 166 to the wheels.
hrmm for maintenance...i've done all the necessary maintenance... maybe a bad knock sensor?.. but, no check engine lights have came on yet and the car pulls really hard IMO. You think i should get my timing advanced also?
It was about 74 degrees inside the building and pretty humid also.. would that be a factor also?
It was a 3rd gear pull with overdrive off.
Old Dec 19, 2005 | 07:40 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Its a possibility that your 13" Cobra rotors contribute to the lower than usuall WHP. When I took off my 04 Maxima 12.6" rotors the car felt more responssive than ever, weight diff was 10lbs compared to OEM rotors. I would have to say the diff was like installing a Ypipe on my Max in terms of my butt dyno. This is why I do not like big brake kits, they look bling n all but take some of the power away- and me on like that.
Old Jan 18, 2006 | 08:49 AM
Ghase's Avatar
I hate to say it but it looks like I'am the record holder for 5gen autos. On the dyno, my car made 193.55whp with an ecu problem, and 4 bad 02 sensors.
Old Jan 18, 2006 | 08:51 AM
Ghase's Avatar
That's without SC being installed....LOL
Old Jan 18, 2006 | 09:25 AM
NmexMAX's Avatar
dot dot dot ...
Figured that much
Old Jan 18, 2006 | 10:43 AM
Ghase's Avatar
Originally Posted by NmexMAX
Figured that much
I should kick your butt for flaming me the last time I post the 238whp. But I hate to say it, but you guys where right all along. The guy guy at the dyno place said my car would make about 210whp, if the 02 sensors was plug in and working.
My tq was also like 211!!!!
Old Jan 18, 2006 | 12:20 PM
NmexMAX's Avatar
dot dot dot ...
2 of my 02 sensors are in my trunk and have been for my last 9 runs. Could be my area under the curve problem.
Old Jan 18, 2006 | 08:41 PM
Ghase's Avatar
LOL... I know one thing, I gotta get that fix in order to run the SC, because if I don't the motor will blow.......
Old Jan 19, 2006 | 10:37 AM
sloppymax's Avatar
what gear were the runs done in and are those sae or std?
Old Jan 19, 2006 | 10:43 AM
NmexMAX's Avatar
dot dot dot ...
With our luck, he wont have his run files, all too common.
Why didn't you get these items checked off before you went to the dyno?
Dynoing with known problems seems useless.
Old Jan 19, 2006 | 12:23 PM
SR20DEN's Avatar
VQ Wizard
Somone in this thread with a 2k1 AE/Auto dynoed 194whp SAE with fuel pump/pressure problems.
Old Jan 19, 2006 | 01:14 PM
Ghase's Avatar
What going Sloppy, long time no see. The car was done in 3rd gear with the O/D off. And I the numbers are SAE correct.
Old Jan 19, 2006 | 01:19 PM
Ghase's Avatar
You know that's right, the truth is I don't know how to post with hosted pictures. I need to learn.
[/QUOTE]Why didn't you get these items checked off before you went to the dyno?
I really just went for tuning, but didn't know it will be a problem.......
Old Jan 20, 2006 | 06:05 AM
sloppymax's Avatar
Those are strong numbers. If you do go for tuning again, I would suggest they do the runs in 2nd just because 3rd takes forever and increases the rate at which heat soak sets in. SR replaced the oem fuel pump with me last night so hopefully after a few more little things I will be back on the rollers.
Old Jan 20, 2006 | 08:56 AM
Ghase's Avatar
Thank you, I will dyno again but it will be after I'am boosted. Hopefully around 300whp.......but only time will tell.
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
BobTX10
Oct 7, 2015 08:43 AM
Tmax78
Sep 25, 2015 09:07 PM
