Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Low numbers for 1997 GXE
Old Jan 6, 2006 | 08:45 AM
SDot82's Avatar
Well I have suspected that my car was not making the power it should be for a while now. The first time was when I went to the track and made a 14.60 @94.90 mph. Most people after the 00VI swap trapped around 97 mph or higher (I'm talking about 5sp). At first I thought it just might be my clutch sucking a$$ but not by these numbers 169.7 hp and 186.9 tq. It seems that my VIAS is not working properly because it almost looks like a USIM dyno. I've checked to make sure the cup was still turning at least 10 times the past couple of months and it does. I know I am still running rich but I'll fix that later. Mods: y-pipe, intake, 00VI, VAFC-2 (need to do more tuning), and Underdrive Pulley.
Old Jan 6, 2006 | 09:28 AM
DandyMax's Avatar
3.5 in the works
Looking at the HP curve I'd say your VIAS is activating, but you're right the numbers seem awfully low.
Done a compression check lately? Any KS codes? That'd be the first 2 things I'd check..
What size/weight of wheels do you have? That could influence it too...
Old Jan 6, 2006 | 09:43 AM
SDot82's Avatar
Rim size is 15" and don't know the weight. I wish there was a KS code (I've checked that religiously for months and nothing) I'll try a compression check Saturday. But if you look at the my curve it peaks 169.2@5200 and the starts to drop 153.2 @ 6000. When I look at your Dyno chart and others, your making power until Stock redline. Where mines starts to lose power.
Old Jan 6, 2006 | 10:25 AM
DandyMax's Avatar
3.5 in the works
Yes but the drop off is still very little compared to the USIM. You don't have an ECU do you? The dropoff in power up high (compared to some other VI dyno's such as mine) could be due to several things, such as not having enough timing (aftermarket ECU vs stock), not enough airflow (intake and/or VI config etc).
I'd still check compression though. And you're a 5-spd right?
Old Jan 6, 2006 | 10:26 AM
SDot82's Avatar
Yeah I'm a 5sp,no ecu just VAFC-2 which I need to adjust.
Old Jan 6, 2006 | 01:15 PM
RA030726's Avatar
I'm nutty for Nissans
you are a little rich but that alone wont drop power than much. you must have some other issue.
Old Jan 7, 2006 | 09:45 AM
SDot82's Avatar
Just did the compression test and the results are:
Front: 183, 190, 190
Rear: 195, 190, 195
So is that front @ 183 bad or what?
Old Jan 7, 2006 | 10:39 AM
Kevlo911's Avatar
Kevlo for President
No compression is good. You really need to make that AF line FLAT.
Old Jan 7, 2006 | 12:53 PM
SDot82's Avatar
After taking off the manifold I found that the cup was loose enough to where it just barely turned the power valve. So now I have to figure out how to fix it since I already jb welded it once, any suggestions?
Old Jan 7, 2006 | 01:39 PM
Kevlo911's Avatar
Kevlo for President
Get it welded.
Old Jan 7, 2006 | 06:46 PM
SDot82's Avatar
Well I ridded up something, I will let you all know tomorrow when I put it back together and test it out.
Old Jan 8, 2006 | 07:20 AM
rick's 92's Avatar
why is it so low.
Old Jan 8, 2006 | 08:45 AM
s0ber's Avatar
I get peak power at 5700, def your VIAS.
Old Jan 8, 2006 | 08:46 AM
s0ber's Avatar
Did you use JB Weld oG or JB KWIK?
Old Jan 8, 2006 | 08:47 AM
s0ber's Avatar
BTW: Do you have the run files?
Old Jan 8, 2006 | 11:46 AM
SDot82's Avatar
He printed them out so i will just type them up in excel and send them to you. What i did was drill a bigger hole in the cup so it would sit down further this way the jb weld had more contact with the bolt. I took some pics don't know if they turned out but I will post pics if anybody wants to know what I did.
Old Jan 17, 2006 | 12:40 PM
alsummax's Avatar
New To Site Wtb Iacv Remote Adapter Plate
Old Jan 17, 2006 | 01:09 PM
NmexMAX's Avatar
dot dot dot ...
And the dyno forum was the right place to post this?
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
bigdogsteve
Jan 31, 2018 04:18 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
